Tire pressures
Tire pressures
What tire pressures are you running. With my '07 GT3 and also my '09 C2S the recommended pressures (printed on the door sticker) were 37psi front and 44 psi rear. I noticed on my 2011 GT3 the door placard says 30 front and 31 rear. I know in recent years Porsche has reduced the tire pressures for a softer ride but I think this may be too soft as a baseline pressure.
OK I agree I had to go back in my memory to remember what the pressures on my GT3 997.1 was. So what I am gathering is that closer to the placard of 30/31 front to rear is a good start.
For LVDell 37/44 were the pressures on my '09 997 and I thought it was the same on my '07 GT3 long gone but not forgotten. As I stated above I will set them at 30/31 as a start unless others with 997.2 GT3's chime in. Tires right now are Michelin cups but I will also run Michelin Super sports on a second set of wheels.
My 2007 GT3 says front 29 rear 31 for MPSC tires. When i ran MPSC, thats the pressures i ran.
With my Pilot Super Sports, Im running front 31, rear 34 cold. In spirited canyon driving that heats up to hot pressures of front 34 rear 37/38
Id be interested to see what others running super sports are using
what kind of mileage does that give u on a set. Ive been able to get 12-15k out of the rears on MPSS, fronts ive been able to do over 20k
Carrera S numbers actually were 33/39 2005-08 and 34/39 09-12...except the Carrera GTS and C4s were 34/37. These car came with different tires and a different suspension than GT3. That's the reason behind the pressure differences between these cars.
Partially Loaded (2 ppl w/o luggage) cold
Front 34 psi, Rear 40 psi
Fully Loaded (2ppl w/luggage) cold
Front 37 psi, Rear 44 psi
My outer shoulders are spent from track use but the centre and inner edge of the tyres is okay... On track I run them 38/39 hot...
