Q: I'm upgrading the clutch. Should I also replace the clutch slave cylinder ?
While having the car up in the air with the transmission bell housing pulled out to replace the clutch, is it a good idea to also replace the clutch slave cylinder, or should I simply keep the old one, if it's not leaking ?
Not on a Porsche but it seems everytime I pull the trans on my BMW track car the ATE slave bites the dust. If you don't plan on pullling it often and the part isn't crazy expensive I would replace it. I do anytime I pull the BMW one. Probably the same ATE brand.
