Will 12x19 ET 45 fit a GT3 MkI
1010tires.com has a good offset calculator. Et45 will be out set by a lot so you will need to see what it is and measure. Most gt3rs run 12" wide et48 and those are out to the edge so my guess on a narrow body gt3 you will rub...even with -2 rear camber
I'm pretty sure it will rub
I run a 325/30 on my GT3 with a 68 mm offset and the clearance is minimal. It doesnt rub with this set up but it is close. 2.5 degrees of camber in the rear
