NT01's: when to get new ones?
That is the dreaded tread splice issue. Huge problem seen on 275/35-18 used on E9x M3s. There was a period of date codes that seemed affected, but new production seems okay. Many M3 folks contacted Nitto to get free replacement. I have a new set but have not tracked them yet.
Mine are 245/40/18 and 305/35/18, purchased in January 2014. Do you know of any M3ers that kept driving on them? I talked to a Cayman owner I know who says he kept going on them. The split isn't that deep (he said) and it went away as the tire wore. I'm hesitant to try that. Thank you.
they shouldnt crack like that. What pressures are you using? Perhaps they are part of the bad batch?
I have 12 track days on my nittos and they do not look like that....
Fellas here in florida run em to the cords!
Hey guys, I've got a question about my Nt-01's. So far I have 8 days on them and must have run over some debris. I'm no where near the end of their life but want to know if you think I should change this out? Here's a pic. As you can see its in the main tread block and is not overly deep. Do you think I can get through this season on them or should I replace it? If I do replace it should I do them both or can I get away with just 1?
![popcorn](https://rennlist.com/forums/images/smilies/popcorn.gif)
![grr](https://rennlist.com/forums/graemlins/cussing.gif)
I have two sets, one from last year, and a brand new one from this year with no issues. Every R-comp has issues from time to time, and to be honest, the 911 loads a tire very heavily. If you overdrive them while brand new, on a 911, they will grain slightly, but that's because of user over-driving, not because of a defect in the tire. Driving to and from the track with lots of negative camber may be heating the inside to much and causing splits on the track.
A LOT more M3 owners drive to and from the track, perhaps that's why they are developing more cracks as well.
No idea really, but I'm sure Nitto will figure it out.
In general, user error tends to be a contributing factor. Make sure you guys are running them at correct pressures, bring them up to temp carefully....don't just go out on the outlap and set flyers...never a good idea.
Seems to happen on fast tracks, there something that tears them apart.
For RS drivers; I still have RA1's in RS size left!
Shaved to perfection.
$250 shipped and going up $25 next week and another the week after that.
Thanks Mvez for the info. I put a request into Nitto to see about the splitting issue. Will post my findings. What pressures are you running? I know there are MANY variables, just curious where you are at.
One set I threw out, one I drove through it as they were pretty low when I noticed it and as the Cayman guy stated, for me, the crack went away when the tire got to where they are good.
Weird with the loads on the rear of our cars I've never had an issue with the 315 rears. You'd think that's where you'd see it.
I do drive mine to and from the track for what it's worth.
I'm sure Nitto will give some guidance.
I've yet to see chunking or splitting. Running about 32-33 hot front, 34-35 hot rear and feels good. I'm a little faster now so this set will probably only last me about 6 days. I drive to and from track.
Appreciate the pics, will keep an eye out on this.
