Help needed: "Camshaft sensor open circuit" error code
Hi all,
Would appreciate some help. I had the engine out on my gen.1 GT3. They changed the valvelifters and the bearings in the engine. The car had stood for 1,5 years and one of the valvelifters were´nt holding the pressure. At the same time when the engine was out they changed the bearings on in the engine as a precaution. They also installed an FVD flash to ECU , changed for a lightweight battery and installed a Cup exhaust.
Now, I have a problem with the car. They can´t get it to run properly and the computer gives out the error code "Camshaft sensor open circuit". It means that the camshaft timing doesnt work. They changed the battery to the standard one, checked that the camshaft is in the right position and changed the sensors in the engine for the camshaft and uploaded the normal software in the ECU.
Nothing seems to work, anyone have any good ideas or possibly had the same kind of problems?
matias
matias
Hi all,
matias
matias
Since your engine has been out I bet you one of the GROUNDS for the computer is not connected properly or not grounding properly due to corrosion.
Former Vendor
9xx:ltä poimittua:
Muistin juuri lukeneeni vastaavasta tapauksesta rennlistillä.
Tyypiltä oli hajonnut vauhtipyörällä oleva kierroslukutunnistin. Uuden tunnistimen asennuksen jälkeen toimi juurikin mainitsemallasi tavalla. Eli toimi normaalisti 3500rpm asti. Sitten ei millään.
Ratkaisu tuohon autoon oli erittäin outo, jostain syystä uusi anturi antoi liian tehokkaan pulssin isommilla kierroksilla. Tämä teki taas sen, ettei ecu ymmärtänyt pulssia.
Anturi oli säädetty shimmilevyillä kauemmas hammaskehästä ja homma rupes rokkaamaan.
Se, että voiko vanha anturi hajota ja aiheuttaa saman ongelman?? En tiedä. Tuli vaan mieleen...
https://rennlist.com/forums/996-foru...r-problem.html
Or grounds, or crank position sensor signal wire problem. Take it to AC for diagnostics
