997 GT2/GT3 Forum 2005-2012
Side muffler delete question
Old 10-03-2013, 12:47 PM
  #31
Spyerx
Spyerx's Avatar
Received 1,785 Likes on 1,087 Posts
1. No, vacuum line.
2. yes. assume you mean the valve on the muffler? Yeah, just unhook the hose.
3. Yes, plug them with a vacuum cap or plug you can grab at any auto parts store.
Originally Posted by Gauss
I also have a question.
I have started to remove my side mufflers and I want to install RPW's link pipes (which I kindly received from CRex, thanks again).
I have now the side mufflers still connected to the little valve controlling canisters. I'm too afraid to disconnect.
1. Is there oil in the line ?
2. Is it safe to just unplug the line from the canister, and if I do unplug,
3. do I have to seal the loose end... what about back pressure issues if I don't seal off?
In case it matters, I have the electrical switch unplugged (the one in the motor bay).
I appreciate all helpful piece of advice.
Old 10-03-2013, 02:00 PM
  #32
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Anyone have pictures to post of this setup??
Old 10-03-2013, 02:20 PM
  #33
drl
drl's Avatar
You can also plug with a little screw, dont know size but i can look and post pic later. If you pull it, that line will pop right off.
Old 10-03-2013, 02:29 PM
  #34
Eddie - RPW
Eddie - RPW's Avatar
I have now the side mufflers still connected to the little valve controlling canisters (also called "vacuum unit for muffler"). I'm too afraid to disconnect.
Hi,
To respond to your questions:
1- No this hose you're dealing with is a vacuum hose, so absolutely no harm in removing it
2- You have 2 options, either unplug from the exhaust and block it, or remove it completely and use a vacuum cap from auto store. The second one is a cleaner installation if you have access to it.
3- Yes you do, as you don't want a vacuum leak.
The plug doesn't matter at this point anymore, just plug it back so you don't have it loose in your engine bay.
Please contact me if you need any help.
Old 10-04-2013, 08:36 AM
  #35
-eztrader-
-eztrader-'s Avatar
any vids of .2 rs with side can delete?
Old 10-04-2013, 10:03 AM
  #36
Gauss
Gauss's Avatar
I thank everyone for their immediate help. Much appreciated.
Eddie, would you mind clarifying your answer to question #2 ? Where exactly shall I plug with a vacuum cap ?
Is this the hose that goes from the solenoid down to the exhaust vacuum canisters ? If so, can I simply seal it off right there, and remove the two side mufflers with their vacuum hoses ?
Also, the vacuum leaves the solenoid through the hose at the bottom (pic is taken from one of Mykimu's valuable mods and the hose has been removed), but where does it go ?
Last but not least... do I run into any back pressure issues when I go this route ?
Cheers,
Joël
Old 10-04-2013, 04:26 PM
  #37
Eddie - RPW
Hi Joel,
I would the solenoid part unmolested. You can just unplug the vacuum lines on the valves (on the side muffler itself).
You also have the option of just blocking the hard line on the back of the car.
I apologize for the pic, but here you will be able to see where you can reach the right side vacuum line. Once you're underneath the car, it's pretty obvious.
I'm sorry but I didn't understand your question about back pressure.
Old 10-04-2013, 04:30 PM
  #38
Eddie - RPW
Yes I have a video from a 996 GT3 that we updated to 997 GT3 exhaust specs with:
997 Center muffler
RPW side muffler delete
997 GT3 Headers
Quick Reply: Side muffler delete question
