Jack Point Jack Stands
You will want a set once you have seen them demonstrated. I own a GT3 so posting my experience here, but could post on the wider site as well. JackPoint Jackstands are great.
They are simply one of the most important tools I have in my garage, and I also bring them to the track with me. I recently bought my second set, so now I can safely jack up my car at all 4 points. These Jackstands remain a bit below the radar, I believe because the owner/inventor has mostly marketed by word of mouth, but after recently seeing the owner/inventor's interview with Jay Leno on Jay Leno's Garage, I thought I would do my part to pass the word on:
http://www.jaylenosgarage.com/collec...ds/index.shtml
Not only do the JackPoint Jackstands solve all of the "jacking point" problems we have all had and discussed on these forums, I simply will no longer get under my car to do work unless it is sitting on JackPoint Jackstands. To me it was a no-brainer to buy these after I first saw them demonstrated:
http://jackpointjackstands.com/
I use the Harbor Freight aluminum jack as well. You can really us any jack, the only issue that ever arises is clearance to be able to get the jack and the pad that sits on the jack in place and in correct position. Some guys just quickly jack the car up without any of the JackPoint components, put a board under the corresponding tire and then let the car down. You will now have the necessary clearance needed to get the jack with jackpad into correct position. What I do is even simpler..I just jack the car up quickly with the plain aluminum jack and then let it back down. It takes time for the car to settle back down to its lowest position, and this gives me enough time/clearance to get the jack and jackpad in place.
I have yet to hear of a jack that will fit under the car with the jack plate. if i remember to drive onto ramps thats what i do, otherwise just put it on a wood block and lower. takes about 20 seconds extra.
Yeah, my low profile aluminum jack with jackpoint plate comes very close to fitting under without any prior jacking/board/ramps, etc. Problem as you know is that the metal pin that sticks out of the top of the jackpoint pad just won't clear. You are probably right about my method though, works for me and no fingers anywhere near pad when sliding under, but why risk it or recommend to others..i agree with you. Just take the 10 seconds to jack, board under tire and go from there.
You mean you quickly slip the jack plate in while the car settles? damn, careful with those fingers....
Brunhoelzl makes a really low profile aluminum jack. One of the few US made jacks in the country. Beautiful
I won't bad mouth these jacks as they are generally a pretty good value. Keep your eyes open if you're using them on a paddock road. If they don't roll on the rough pavement I've seen twisting. If your not careful you could have a tip over. Also be alert to any jack with a saddle (the plate that lifts the car) under 3.5" in diameter. If the saddle is too small and the pad slides as you lift, the pad can get far enough off center to tip under some circumstances.
