997 GT2/GT3 Forum 2005-2012
315 nt01 is not good for 997?
Old 04-08-2013, 02:33 AM
  #31
mooty
GT3 player par excellence
mooty's Avatar
Received 5,660 Likes on 2,327 Posts
Originally Posted by TRAKCAR
245/40/18 but they are no longer sold, we substitute with NT-01 Nitto
335/30/18 but we bought the last few hundred.
275 RA1 wont fit front?
Old 04-08-2013, 06:49 AM
  #32
TRAKCAR
TRAKCAR's Avatar
Received 1,640 Likes on 762 Posts
Can be done but it will kill the fender liners and you cant lower tha car as much as you'd like.
Plus the Nitto's have more grip then the RA1's to begin with...
Old 04-08-2013, 10:21 AM
  #33
deputydog95
deputydog95's Avatar
I'm on my 4th or 5th set of nittos. Great tire. I noticed splitting once. Purely cosmetic on the top layer of the tread. Nothing structural. Session or two and it was wore off. Are there any documented failures or is this concern over something cosmetic?
Old 04-15-2013, 03:18 PM
  #34
ti-jean
ti-jean's Avatar
What tire size are you running and when did you buy it? I'm new to this side of the fence but I've been tracking my M3 for a while and running NT 01. Several M3 guys had tread splicing issues with recent build dates. Here is a list of build dates and reported status. This is for 275/35/18, not sure if the problem is specific to tire size or not.
0811 OK
3011 OK
3511 OK
4511 OK
5211 OK
5211 OK
3212 Spliced
3212 Spliced (3 of these spliced, 1 still OK)
3212 Spliced
3212 Spliced
3412 Spliced (Guessing from Aug-12)
3512 Spliced
3612 Spliced
4112 OK
4112 OK
4212 OK
4312 OK
4712 Spliced
Old 04-15-2013, 03:22 PM
  #35
sstjohn
sstjohn's Avatar
DD hit the crack pipe last weekend. There will be no going back to NT-01's now.
Old 04-15-2013, 06:41 PM
  #36
deputydog95
0811 OK
3011 OK
3511 OK
4511 OK
5211 OK
5211 OK
3212 Spliced
3212 Spliced
3212 Spliced
3512 Spliced
3612 Spliced
4112 OK
4112 OK
4212 OK
4312 OK
4712 Spliced
I've been using them over the past 2 years and I haven't tracked anything regarding purchase dates and batches.
You got that right. Whoah. I have a new set of Nittos too. This would be like using an ipod and going back to a walkman
Old 04-15-2013, 09:44 PM
  #37
mdrums
mdrums's Avatar
ti-jean. I'm running NT01 245/40/18 fronts and no problem with tread splitting. I had major issues with Toyo R888 tread splitting across the tire. I had this issue in late 2011 and I sent 4 R888 tires back to Tire Rack.
R888 is not really a great tire but it was ok for DE because it comes in the sizes but something happened in 2011 and the tire changed and was just awful....less grip and it falls apart and splits so bad it's unsafe to run it. Toyo has issues with R888 from what I've read on other forums and then I met a other DE guys that had the same issue. Also the Toyo RR is splitting too....JUNK!
I drive to and front the track so I can't run Hoosier or Pirelli slicks.
Quick Reply: 315 nt01 is not good for 997?
