RS swaybar torque spec
HI all,
I am looking for the "correct" torque spec for the sway bar. For some reason the front one keeps on coming loose.
Thank you,
Sandro
Thank you,
Sandro
Happens, try a lock washer ... should do the trick.
That's why cars NEED to be nutted and bolted after each event.
Go check your tail lights, they are probably falling.... your frunk is touching the plastic, and scratching it, your engine lid is touching the bumper ... and this is just the beginning.
GT3 player par excellence
i am 200 lbs.
i do 10 pull ups under the car with ratchet on the sway bar nut. my has never came lose ever.
