quiet center muffler only options?
It seems the logical route for a simple lightweight exhaust is to ditch the side mufflers. However, if you really don't want to attract attention, then you want a center muffler that actually works.
So, what are all the center muffler only options and which are the most quiet?
TIA
TIA
TIA
TIA
I'm also interested in side muffler delete (after warranty expires), but one worry I
have is noise restrictions at some tracks. My friend with stock center exhaust and side
muffler delete was kicked out of the local autocross for excessive noise.
Eddie's M&M system is the way to go. The entire system is solid and built to last. At lower RPMs it is not much louder than stock (with valves bypassed) but sounds much better. At full throttle it is music to your ears!
