Excellent - 335/265/18 BFG R1s fit like a glove on the RS
A few folks had me scared that this was going to end in tears - but it worked great. At first they looked like they were going to rub on the rear, but they tuck in as the wheel moves upward. I'm running -3.5 in front and -2.5 in rear, stock heights. That's about as much tire as I can see fitting without mods.
With one more weekend of learning the 911's dynamics under my belt (I finally ditched the nannies), it's not a apples to apples comparison to the 335/255 hohos I tried last time. Best I stumbled into going CCW at TWS on the hoho's was a 1:52.4, the R1s were a second faster today in traffic and higher ambient temps. If the R1s hold up longer than the hoho's 12 heat cycles, they could be a good option. This set was $300 less than a set of R6s.
Nope, the diameter ratio is only 0.5% off stock.
The section width is the same as the R6 (13.5" rear) - but the difference is that the R6's max width is at the rim protector, and the R1's is the face. R1 has a very square shoulder, so it's a tighter fit.
The Penguin King
Great seeing you this weekend btw.
They seemed good, the side wall flexed a bit and the car "hopped" when under extreme load, but never broke loose. I never got enough laps in to check the temperature curves to get the pressures right.
The R6s heat cycled out before they corded (but I still drove on them), so my hope is that R1s will take a few more cycles before they turn into drift tires. One positive thing about the ragged out R6s I was using on Sunday morning was that I learned how to drift the RS through 6,8, and 12 - actually worked to build a bit of confidence.
Likewise, and many thanks for the masterful paddock beverage. I can't believe I've been missing out for so many years.
The Penguin King
Glad you enjoyed. I make them every Saturday when the track goes cold. Come on by any time. There's nothing better than driving your Porsche on the race track, and having a Hendricks Martini chaser!
Love the white gold on the Forgelines. Thanks so much for the tip-off on the "mistakes". I've got a 2nd set on order now, in preparation for racing season.
Let us know how they perform, assuming you decide to keep running them. Hoosier needs some serious competition.
