997 GT2/GT3 Forum 2005-2012
Torque Solutions Urethane Transmission mount review
Old 01-21-2013, 06:40 PM
993GT
993GT's Avatar
Pressing out the old bushings isn't too bad of a job to do, if a press or a local shop with a press is hard to come by, can always use a small saw and cut through the outer steel band of the old bushings and 'peel' the old ones out, not a fun job but whole job should take under a hour to do...if anyone wants to do the T.S. style way, can reuse old bushings if in fair/unbroken shape and use a quality window urethane(as used to secure windshields inplace) available at many partstores, clean bushings with solvent and squeeze urethane into the gaps, common mod in the 944 world, $15 or so...
Old 01-21-2013, 07:01 PM
Mvez
Mvez's Avatar
I've thought about using the 3M window weld method....
Old 01-21-2013, 07:05 PM
993GT
993GT's Avatar
did it on my last 951, and will likely do it to my current one as well, works great, depending on what options I find for complete replacement poly bushings, might do the window weld trick as well when I bring home a '6GT2..
Old 01-21-2013, 07:07 PM
993GT
993GT's Avatar
and if anyone thinks a 996/997 trans. mount is weak/bad, you'll laugh at the 944/951 ones
Old 01-21-2013, 07:42 PM
P.J.S.
P.J.S.'s Avatar
Originally Posted by Mvez
I tried buying the torque solution unit recently and it is not being sold anymore until the newer version comes out. They are working on a better way to pour the polyurethane into the mount. I think it's a 60A or 70A shore hardness.
The GMG mounts are harder, 90A shore hardess, but have the "ears" on them, which I like, and prevent the mounts from weakening or coming out. However, I hate pressing out old bushings from aluminum.
Not sure which one I'll go with, maybe I'll wait for the next TS version, but definitely doing this mod.
I am waiting for the "new" TS one now as well
Old 01-21-2013, 08:37 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
TMs sure make a difference on these cars.................it is amazing, isn't it!
Old 01-21-2013, 08:59 PM
DRPM
DRPM's Avatar
Please give me a heads up when the new one comes out.
Old 01-21-2013, 11:13 PM
P.J.S.
P.J.S.'s Avatar
Will do - I sent a message to Eddie at rpw today and he said he would look into it and get back to me
When I hear I will update the thread
Old 01-21-2013, 11:14 PM
hershann
hershann's Avatar
My short review on the TS transmission mount - installed previously a few months ago.
Pro:
- gear shift is slick and nice, less baulking at the 2-3 shift
- accelerator response is more immediate
- car feels more 'together'
Cons:
- if your using the RS flywheel - you can hear and feel the rattling by about 25-30% more at least
- Noise during driving and idling is significantly increased - and is a bother if car is a daily driver.
I took out the mount 3 days after installing - though the car drives great - the noise increase is too much for my daily driven car.
It will be a no brainer for a mostly track driven car though.
Also - when I removed the mount - 2 large chunks of the the polyurethane actually broke off from the mount - hopefully the quality control has improved.
her shann
Old 01-21-2013, 11:42 PM
993GT
993GT's Avatar
One thing that's nice about a true replacement poly bushing(because it is a solid/consistent material vs rubber with added urethane) is NVH can be adjusted by removing/drilling out parts of the bushing essentially making it 'softer' or more compliant, while this won't make the driveline as responsive as the solid poly bushing it will still control driveline 'shift' better when drilled than the OE rubber bushings...
Old 01-22-2013, 12:18 AM
NorthVan
NorthVan's Avatar
Does anyone have one installed with solid engine mounts?
Old 01-22-2013, 12:22 AM
993GT
993GT's Avatar
with true solid(metal) engine mounts best bet is to go with solid(metal) trans. mounts to avoid stress/damage to cases or mounting points
Old 01-22-2013, 02:23 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,617 Likes on 2,306 Posts
a very very BAD idea
Old 01-22-2013, 02:30 AM
DC640
DC640's Avatar
Do you want to a little energy absorbance on these bushings? Since I think rock solid mounts will transmit all the energy to rest of the car... I guess it is decreasing range of movement but allowing slight "give" to absorb energy?
Old 01-22-2013, 02:41 AM
mooty
mooty's Avatar
semi solid good
solid not so good
one purple pill good
one bottle purple bill..... ER.
Quick Reply: Torque Solutions Urethane Transmission mount review
