Sport Bucket Help
Sport Bucket Help
Help!
Just purchased a pair of sport buckets out of an RS and started to install them. When I checked underneath them, the yellow bracket connector was missing. Am I safe in assuming these are typically included with the seats? Also wondering if the connector on the standard sports seats could be transplanted.
In the two sets I've owned they have been with the seats. If you are looking at 997.2 to 997.2 variant they should work. I can't speak to the 997.1 Strange that they didn't have the connectors.
Also just realized that the belt connectors were not present. Hoping I can grab those too.
Hope you find the connectors. Does the seller have them?
Working on that now.
I am not sure which connector you are talking about. On both sides there is a connector for seat belt that snakes through the seat from the seat belt buckle. On the passenger side there is also a pressure sensor to arm/disarm the passenger side airbag. If you had power seats, there is also a module mounted under the cushion for the driver's seat that controls memory and mirror tilt-down. In this case, the connectors for the module will stay unplugged and you won't have memory or mirror tilt-down functions when you swap seats.
It's the yellow box connector that the wire from the car connects to. Search "seat DIY" in this forum to see a picture. It was removed from the sport buckets by the shop that removed the seats from the car.
GT3 player par excellence
pm Larry cable
blue gt3 at LS avatar
last week he JUST did heat ur doing now
We've spoken. Thanks Mooty! Sorting it out with the seller.
glad it worked out
Larry is the expert now!
let us know when u move up to bay area
Does anyone have a copy of the PET for the Sport Bucket that they could send me? Specifically I'm looking for parts and part numbers for a few of the connecting pieces in case I need to order. Thanks!
Mooty: PS - I'm here.
Derek - Mooty mentioned it. If I can get the GT3 up here by then, I'm in.
Brunch meet maybe in a couple of weeks? Sounds like most of the guys here are in the city or S. Bay.
