997 GT2/GT3 Forum 2005-2012
oem shifter feel
Old Oct 30, 2012 | 06:46 PM
hotwired's Avatar
hotwired
Default oem shifter feel
I recently bought a 2011 GT3RS and I'm finding that the shifter on my car requires a bit of effort to click into gear, especially from 1st to 2nd. Is this the normal behavior of the oem shifter? I don't get any grinding or noise and I'm matching revs. Is it supposed to click in with a tiny bit of force or is it supposed to be completely smooth?
Old Oct 30, 2012 | 11:17 PM
JJE997.2RS's Avatar
JJE997.2RS
How many miles? My shifter felt somewhat notch and firm at first for the first 2500 miles, and then kind of got looser and smoother after that. Kind of like it had to break in...
Old Oct 30, 2012 | 11:36 PM
hotwired's Avatar
hotwired
The car had 2600 miles when I bought it and is now almost at 4k. Gear oil change helped a bit but still noticeably notchy.
Old Nov 1, 2012 | 10:16 AM
hotwired's Avatar
hotwired
Would cable adjustment help some?
Old Nov 1, 2012 | 10:37 AM
tcsracing1's Avatar
tcsracing1
did you check the tranny oil drain plug for filings?
Old Nov 1, 2012 | 10:43 AM
Richie18's Avatar
Richie18
I have the same feeling in mine. Assumed it was normal? I have over 5K miles on it now with plenty of shifting.
Old Nov 1, 2012 | 11:58 AM
hotwired's Avatar
hotwired
I just had the transmission oil changed and it was very dark, almost black, but there weren't any filings in the fluid itself. I didn't ask the shop to examine the drain plug.
Old Nov 2, 2012 | 01:06 AM
10 GT3's Avatar
10 GT3
It will always be a lot stiffer when cold. They are also a lot tighter without a lot of miles. Mine actually tightened/became stiffer around 10k miles. At 15K it really smoothened out and became a lot lighter. Put a few DEs on it and it should loosen up.
Old Nov 2, 2012 | 01:33 PM
hotwired's Avatar
hotwired
Thanks everyone for the input. Do you guys find that 1st to 2nd is especially notchy? Even after warmed up?
Old Nov 2, 2012 | 04:13 PM
Bono's Avatar
Bono
Some additional thoughts for you. Before my current 2011 GT3, I owned a 997.1 Carrera S and a 997.2 Carrera S. Both Carrera S's shifted like butter. From Day 1 the GT3 has always been stiffer, with some notch. It definately requires more deliberate effort, and that is one of the things I like about the car. Could be my imagination, but when I put in sport mode, the shifting feels even stiffer. It is just my opinion, but I feel this is normal given heavier shifter cables. Now if your saying you are having difficultly going into 1st or second, as in the car won't go into gear, that doesn't sound normal.
Old Nov 3, 2012 | 01:22 PM
Thork'sGT3's Avatar
Thork'sGT3
I agree with Bono. My 997.1 GT3 has 60,000 km and the shifter is still a bit notchy. I think what you are feeling is probably normal. They are a robust trans. I would not worry about it and enjoy the car!
Old Nov 3, 2012 | 04:33 PM
PAULUNM's Avatar
PAULUNM
I just put a 997.2 GT3 shifter in my 996tt, the 1st to 2nd shift is noticeably more notchy now.
I assume it will loosen up over time.
Old Nov 3, 2012 | 04:48 PM
Hard Motorsport's Avatar
Hard Motorsport
Former Vendor
Time for a upgrade
Old Nov 4, 2012 | 09:10 PM
hotwired's Avatar
hotwired
Thanks everyone for the input. Looks like I just need to put on more miles
