New PCA DE centerlock tech inspection requirement
This just arrived in my inbox from Pete Tremper, PCA National DE Chair. Can you CL experts chime in on whether this inspection procedure is adequate/effective & doable for the average volunteer in the paddock. I note too that this new mandate will require all CL cars to have their dustcaps OFF during tech inspection.
Note: I removed Pete's contact info just to save his privacy a bit. Otherwise this email has not been edited.
We will need to implement this in our PCA Region. Please help me understand whether or not this is an effective process and if not what can be done to improve it on the ground at our next DE.
Thanks guys!
<begin quote>
October 25, 2012
To: Regional DE Chairs and Chief Driving Instructors
From: Pete Tremper, PCA National DE Committee Chairman
Re: Center-lock Wheel Inspection at Grid Tech
The purpose of this note is to provide you with information concerning the correct way to inspect center-lock wheel equipped cars at Grid Tech. You should verify that:
1. The center-lock nut has been replaced in accordance with the Porsche recall notice. (Note: The newer nut will NOT have torque a specification written on the face of the nut - See below)
OLD (labeled with 500Nm torque spec)
![](http://tavernetti.smugmug.com/photos/i-HqGsW3R/0/M/i-HqGsW3R-M.jpg)
CURRENT (No torque spec shown, nut color is irrelevant)
2. The locking mechanism is fully engaged (See attached photos below)
Hub locked (center spline is flush to nut surface)
![](http://tavernetti.smugmug.com/photos/i-jPDvS7x/0/M/i-jPDvS7x-M.jpg)
Hub NOT locked (center spline is recessed)
![](http://tavernetti.smugmug.com/photos/i-GLQPqtr/0/M/i-GLQPqtr-M.jpg)
3. The wheels were torqued in accordance with Porsche specifications. (Note: You must verify with the car owner that the wheels were suspended off of the floor at the time of torquing as shown in the Owner’s Manual.)
If you have any questions, please contact me.
Pete
This email was sent to Region Chief Driving Instructors and National Staff and Region Presidents by Vu Nguyen and the National Porsche Club of America, Inc. You may opt-out of receiving emails from PCA National by updating your PCA membership record at our web site. Read the PCA privacy policy.
© Copyright 2012 Porsche Club of America Inc. All rights reserved.
<end quote>
Thanks guys!
<begin quote>
October 25, 2012
![](http://tavernetti.smugmug.com/photos/i-pztqqLS/0/M/i-pztqqLS-M.jpg)
Pete
<end quote>
This is difficult to implement, but not impossible. It will require a separate area for CL inspection where each member's car gets lifted, corner by corner, and each wheel untorqued, retorqued, untorqued and finally retorqued (in that order) to 600Nm / 450lbft using a calibrated instrument. Then the center splines are re-seated and checked.
Alternatively, you can have a qualified tech "sign off" on this procedure in each member's pit.
The inspection procedure he sent you is doable by the tech volunteers. And the things in the inpsection that are called out are very important. Whether it's adequate/effective is debatable. Other questions would be how many hr do the CL's have on them. What tires have they been used with. Have they ever been operated at improper torque.
I think it's a step in the right direction. Some months back, I asked our local POC tech steward about implementing something similar and he just shrugged it off. Given the collateral damage that can occur, I think it's in all organizers best interest to implement some procedure to reduce potential risk. Too many owners who simply don't know or don't care about the process.
I think the implementation could be:
1. the signoff on a separate PCA CL tech sheet by a dealer or qualified shop showing steps 1 - 3 have been completed, followed by a visual inspection of items #1 and #2. If either is failed at the track, they must be remedied before the car can go on track;
2. if no prior signoff, follow steps #1 and 2. For step 3, the owner should be asked to demonstrate an understanding of the torque spec and process. If the owner is not able to recite a basic understanding, they should be directed to the Porsche bulletin, possibly even given it (unless that is too much of a potential liability concern).
I think if either is failed, the driver be asked to return another day. The event description should have a clear note explaining special instructions for CL owners. Yes, the process is a PITA but look at the design we are dealing with. I think it would help educate owners who track about the process though.
I should add that I'm not sure it's known how many hrs they can take before they time out. And it probably depends on how grippy the tires used were. There is internal documemts re: determing damage due to improper torque. It's not something to be done in the tech line though.
I witnessed CL inspection procedure at NJMP Lightning with Pete there. Caps removed before going through tech a simple procedure to verify properly locked. Then keep your fingers crossed. Hubs will probably become a wear item after "X" number of hours.
Better late than never. I could never understand why it was not required in the past.
Step 1 about the recall: If recall was not carried out, owner should be informed and asked to get it done before the NEXT event.
Step 2 is appropriate and should have been there from the beginning. It is not a hardship to inspect this at tech.
Step 3 might be a bit much to ask of an owner who does not get involved in the maintenance of his car. This should be covered on the tech inspection form, and signed off by the tech who did the inspection.
I do see a lot of knuckleheads at the track that have the nut stuck in and not pulled out where it should be. I usually try to help them out and explain the problem if they are unaware.
Good for PCA. Doubt this inspection will make any difference. Improper torquing procedure is what will make the hubs fail and you cannot see that at a tech inspection. I should know
Good for PCA. Doubt this inspection will make any difference. Improper torquing procedure is what will make the hubs fail and you cannot see that at a tech inspection. I should know![Wink](https://rennlist.com/forums/images/smilies/wink.gif)
Plus 2 on what GT3DE said...only a few guys I know that have center locks actually do,there own wheel work and do it correctly and others I've talked to are either clueless and did the procedure wrong.
It's good PCA noticed that Porsche Center Locks have issues and the car owners have issues. Porsche really messed up big time and never will admit it with putting this stupid center lock system on its cars.
When Giesha loses a wheel you all have something to work about
