997 GT2/GT3 Forum 2005-2012
What is this grinding noise at startup?
Old 10-01-2012, 03:03 PM
tasman
tasman's Avatar
Originally Posted by Hoosier_Daddy
... between the occasional smoke, rattle and squealing brakes the locals think my car is a pile of crap and always ask, "How much do those cars cost? My Honda never does that!"
Character. That's why I bought mine.
Old 10-01-2012, 04:32 PM
NJ-GT
NJ-GT's Avatar
Dell,
I think the sound comes from the side muffler valves (the ones bypassed by the Sport button). For these valves to be closed (quiet sound), they need 12v current on the solenoids and vacuum pressure to push the actuator rods and keep the valves closed.
There is a small amount of vacuum pressure left in the car when the car is no longer running, but after a long while this pressure is almost nil. When you startup the car, the solenoids are receiving a 12v signal, and send vacuum to the actuators which would push the rods and close the valves. While enough vacuum is being built, the rods don't have enough pressure to close the valves, and it is on this transition where the exhaust gases can make the valves shake (flapping valves) creating this grinding sound, as soon as enough vacuum pressure is built, the actuator rods fully push the valves closed.
A 996 GT3 would not make this sound, because it uses a traditional muffler.
When the 997.1 and 997.2 engines are started, these valves are in open position (the rods are not pushing the exhaust valves closed), and as soon as the car build vacuum pressure( less than 2-3 seconds), the solenoids have enough pressure to push the rods and close the valves.
It would be easy to test, put metal wire around the two valves if the car has been sitting for a long time, and start it up, that transition sound should not be there.
By the way, my Fiat had a very similar noise, it uses the same brand solenoids used by VW in the 997 Aero Beetles. The sound went away when I switched to a custom muffler that eliminates the valves. Recently I went back to a valved muffler, and the sound just came back.
Old 10-01-2012, 04:38 PM
RAudi Driver
RAudi Driver's Avatar
Received 2,735 Likes on 1,637 Posts
^^ Sounds like the answer.
Old 10-01-2012, 04:55 PM
LVDell
LVDell's Avatar
Originally Posted by NJ-GT
Dell,
Thanks Rad! That is exactly what I was looking for.
Old 10-01-2012, 05:20 PM
911SLOW
Admin
911SLOW's Avatar
Dell,
Rad 996MK1 gt3s do it, 6mk2s do it, 7.1s do it and 7.2 do it too..
https://rennlist.com/forums/996-gt2-...le-on-gt3.html
We have to wait for the 991 cars to stop the terrible noise from the obsolete Mezger engines.
Dell I heard your clip, it's the normal noise probably coming from the tensioners..
At one point I had an email exchange on this issue with a UK friend and he brought up the Variocam theory. Basically the revised system of the 7 cars enhances the cold start noise when the car is sitting for a long time and the oil dries up and loses pressure.
You can read a short version courtesy of Pistonheads.com
"GT3 start-up rattle
Aside from chain tensioner and chain drive noises on start-up (similar to the other versions of the engine type) the GT3 engine uses 'Variocam' - a system that enables active adjustment of valve overlap by changing the position of the Inlet camshaft in relation to the Crankshaft and Exhaust camshaft. The electro-hydraulic system on the inlet camshaft sprocket has oil pressure fed to both sides of the sprocket element to fix it in place; adjustment is effected by changing the pressure on either side of the sprocket to rotate the element (left or right).
On the 9x6 and 9x7 models with second generation Variocam the sprocket is mechanically fixed until oil pressure builds and takes over sprocket control after start-up and it is from here that the noise emanates - In the GT3, the sprocket element isn't fixed so as the engine is cranked the sprocket is free move in its designed adjustment range (stop to stop / rotationally left to right) - as the cam loads against the next set of valves to open the camshaft moves to its 'left stop' (potentially with a 'clack'), as the engine continues to rotate the camshaft reaches peak valve lift and the lobes begin to ramp back off of the valves; at this point, because the sprocket isn't at full tension / pressure, the camshaft is helped round by the valve spring pressure and can rotate to its 'right stop' (potentially with a 'clack' - see where this is going??)
As oil pressure builds (almost instantly) the 'clack, clack' sound is lessened to eventual 'silence' (maybe not the right word!!)
Depending on the oil temp, how long the engine has been left to stand, the position of the cams when the engine was last stopped etc the noise is more or less apparent - in no way does the noise suggest a fault, more just a characteristic of the system.
I have seen one case on a Mk1 GT3 where the oil valve in the camshaft housing worked loose which allowed faster pressure loss / loss of oil retention once the engine was stopped (the valve could not have failed completely but the relative movement around where the valve should have been fixed was enough to make the above noises more prevalent)."
Best,
John
Old 10-01-2012, 05:27 PM
LVDell
LVDell's Avatar
Gotta love that Metzger!
Robocop305 (01-19-2023)
Old 10-01-2012, 06:33 PM
Yoops Racing
Yoops Racing's Avatar
It is slightly unnerving hearing this for the first few times....especially after hearing a 99 C2 start up that was plaqued with the IMS Bearing Issue.....
Old 10-01-2012, 06:54 PM
Izzone
Izzone's Avatar
Dell,
Rad mine has no side mufflers or actuators
same noise
Old 10-01-2012, 07:02 PM
User 11121
User 11121's Avatar
So glad to hear LVDell's account of the grinding noise during start-up. Have the same issue when my .2 GT3 is parked for the entire week.
I must admit that the intermittent smoke and grinding noise during cold start is not fun and down right embarrassing.
Thanks to NJ-GT and 911Slow for the possible explanations. So it's fair to assume this comes with the territory and should be classified under behaves as expected?
Old 10-01-2012, 07:11 PM
DRPM
DRPM's Avatar
Rattle and hum
normal, mine does it after sitting for 4-5 days.
Old 10-01-2012, 07:21 PM
MarkG123
MarkG123's Avatar
Mine makes the same noise. I was told it was an oil scavange pump priming after initial oil picking up.
Old 10-01-2012, 07:51 PM
MarkD
MarkD's Avatar
Best,
John
^^^ THIS ^^^
When the car sits for an extended period of time, the hyrdraluic chain tentioners bleed down a bit.
wait, that was all in the quoted piece from pistonheads in your post
Nevermind...
I recall having the power to delete a post in the past... seems to be gone now.
Old 10-01-2012, 08:41 PM
RAudi Driver
My car sits for weeks at a time and I do not have the bees in a can sound. Getting close to 30k on the clock and it's been quiet to this day. Hmmm, maybe something is wrong with my car.
Old 10-01-2012, 10:26 PM
Turbohead
Turbohead's Avatar
Hey Man
You pay extra for that noise !
Old 10-02-2012, 06:54 AM
Greentree
Greentree's Avatar
If you listen closely you'll hear the rattle just as the oil pressure starts to come up. I decided over the years that the rattle must be air purging from the oil galleries. It's probably making the oil pressure regulator internals rattle as the air passes through.
Quick Reply: What is this grinding noise at startup?
