SC/TC Off or On
If you are smooth leave it on and see where it assists or saves you. I always leave it on when I get to a new track. Gives me the confidence to try a bit harder earlier and I never found it ate my rear brake pads too bad. If it comes on all the time and it really slows you down, you are not doing it right unless you are Ricky Bobby..
Some corners you can cheat it will make you faster, if you really have a track nailed and you are within a couple of seconds of pro drivers it will usually slow you down.
With it off saving a car has to be instinct......if you wait to think the rear will already swap with the front
Learn to drive too quick without out it, once turned off it will be difficult to fix a mistake
I keep it off
I keep it off
TC is fine methinks. On or off it ain't doing that much. Although if you do get the tail out its frustrating to feel the cut-out. I never have it on.
SC is another story. I've seen many a driver lose 3-5s/lap instantly upon switching SC off and then pit their cars with their confidence in tatters. I think a lot of people responding are actually extremely good drivers and are undervaluing how good this system actually is.
the gt3 is a great system in that the intervention threshold is quite high.
other cars intervene very early and put a damper on the fun.
turning off nannies will make the car rotate.
you can use some minor rotation on slow corners to get better exit angle.
too much rotation, and you can spin. your foot controls the amount.
SC off seems more natural from apex to track out. Back end doesn't tuck in by itself (which is a weird feeling) and balance is easier to maintain with smaller throttle and hand inputs. I actually think my diff works better with SC off. Haven't driven enough with SC+TC off to give an opinion, especially since I only recently got my car handling right.
On my car I only have the option of SC off, or SC+TC off, no TC off only.
I leave them on at a new track or if i am feeling off my game.
TC seems much less regularly intrusive than SC. It only kicks on when a suvstantial mistake is made and in those instances you know it is on - you can feel it, you can see it on th dash. And in those instances i can appreciate it.
SC on the other hand affects the cars handling characteristics on a more regula and subtle basis. Often i feel like i am driving a tank with it on. I cant adjust the cars movement cause i cant feel it. My first session ever at laguna i left both on and ended up pitting after several laps thinking something was wrong with the car, esp when going through the corkscrew and turn 9. Chatted with a friend about what was going on, turned SC off, and car was perfect.
As i have progressed TC activates less and less frequently. And i can usually predict when it will. SC off the car is way more fun to drive and gives way better feedback.
These are my observations from personal esperience and i have no hard data to support any of it.
my opinion - a pretty simple question of
1 - are you more focused on refining your driving skill -- turn it all off and drive the tire/car (even in rain) - that way you know what the car is doing in response to your inputs
2 - are you more focused on just having fun -- leave it on - the car will help you up to a point, but sometimes difficult to figure where and how it is overcoming your deficiencies (or countering what you are correctly trying to do near the edge)
either way .... better than a day in the office....
the brakes are an even more advanced method. especially fun when you got brakes with bite.
I would get some drift lessons first. Learn to control the car as it goes in oversteer, not only to recover it asap but to also learn to slide and hold the oversteer. If you can manage that you are ready for then the back steps out on the race track. This is something that is hard to learn on an open parking lot. You actually need a "track" with corners to drift through so you have an objective to accomplish.
