997 GT2/GT3 Forum 2005-2012
over and under steer 101
Old 08-09-2012, 05:50 PM
997gt3north
997gt3north's Avatar
Originally Posted by mikymu
We typically do very fine adjustment such as 1-2 psi off the tire pressure (at 28 psi hot
I still stand by my statement that the first 2 are backwards - I only used 40psi as an example to make the point. I have never, ever, raised tire pressure to get more grip - ever. I lower tire pressure to get more grip at the end that needs more grip - obviously up to a point - these are small adjustments as you say.
And, this also makes sense with all the other methods mentioned as well:
- increased tire pressure = more spring = more ride height = more push (at that end)
- decreased tire pressure = less spring = less ride height = more grip (at that end)
I am removing the conversation of street tires that may need more psi because of overly soft sidewalls that basically collapse with track side loads - in that case, and from very low psi, increasing psi may in fact increase grip
Old 08-09-2012, 06:59 PM
mikymu
mikymu's Avatar
Sorry we did not catch the flip on the chart. Excellent point ... fixed!
Old 08-09-2012, 07:04 PM
mikymu
mikymu's Avatar
Originally Posted by TRAKCAR
Than drink more beer. Are you an enjuneer?
Don't like beer ... they don't taste good and alcohol give me gastritis. Once upon a time I was an engineer apprentice
Old 08-09-2012, 07:15 PM
mdrums
mdrums's Avatar
Ok...so we all strive for a neutral car but if it goes 1 way or the other.....
who prefers and car that understeers?
who prefers a car that oversteers?
Old 08-09-2012, 07:19 PM
mikymu
mikymu's Avatar
who prefers a car that understeers?
In a street GT3 I prefer slight understeer to lessen chance of *** coming around. Total neutral in a M3 and Z06. Cup car is a different animal, there are so much grip I treat it like a 50/50 M3 so I like it neutral
Old 08-09-2012, 09:24 PM
GT3DE
GT3DE's Avatar
Cole Trickle: Whoa. Her *** is all over the place.
Harry Hogge: When the rear end's loose, the car's fast. Loose is fast, and on the edge of out of control.
Old 08-09-2012, 09:48 PM
Seth Thomas
Seth Thomas's Avatar
Great chart to print, take the track for a refresher or cheat sheet. One thing it leaves out is what the driver is doing to cause the OS/US and where did it first start. I see a lot of guys start chasing "handling issues" because of tire pressures or ride height but the real cause was a driver input with the throttle, brake or steering.
Be careful tuning your car as you can start making changes that will make the car worse than it already is.
Old 08-09-2012, 10:09 PM
996FLT6
996FLT6's Avatar
Slight oversteer. Mike
Old 08-09-2012, 11:05 PM
mdrums
mdrums's Avatar
+1 that's why I would have a pro driver...a true pro that does this for a living every weekend that totally understands these things...like Seth would....drive the car and sit with me when I drive the car. I would go with settings based on their recommendations.
Old 08-10-2012, 02:01 PM
GT3DE
GT3DE's Avatar
If you are not driving at the limit then none of this matters and won't change a thing...
Old 08-10-2012, 04:45 PM
Veloce Raptor
Veloce Raptor's Avatar
Received 1,566 Likes on 822 Posts
+2
Old 08-10-2012, 05:25 PM
mikymu
mikymu's Avatar
Very true and the nut behind the steering wheel need attention most of the time. This over/under steer spread sheet is a good reference esp after making changes to suspnsion componenets or tire/wheel size
Old 08-10-2012, 06:51 PM
ir_fuel
ir_fuel's Avatar
Old 08-10-2012, 07:07 PM
GT3DE
GT3DE's Avatar
better version
Old 08-10-2012, 07:28 PM
GT3DE
GT3DE's Avatar
http://www.youtube.com/watch?v=BECha...ayer_embedded#!
Quick Reply: over and under steer 101
