997 GT2/GT3 Forum 2005-2012
CL "Braker Bar"
Old 08-09-2012, 08:42 AM
The Greek
The Greek's Avatar
Truck stop sucks....
Wheel has to be perfectly straight or falls off after 2 wheels....
Old 08-09-2012, 09:10 AM
senna
senna's Avatar
I am interested if it works well.
Old 08-09-2012, 11:09 PM
Space Coast GT3
Space Coast GT3's Avatar
Hi 4forme, I'm interested too.
Old 08-10-2012, 01:39 AM
peer
peer's Avatar
I'm interested, truck pedal depressor works ok bracing against the fire extinguisher mount but is often a PITA
Old 08-10-2012, 09:18 AM
911GT3
911GT3's Avatar
Interested. I am afraid my wife's right leg is going to get huge.
Old 08-10-2012, 10:39 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,654 Likes on 769 Posts
Originally Posted by 4forme
Anyone interested in a racheting bar device to depress the brake pedal while changing CL wheels and to torque to specs? Turns it into a one person job. I can make them for those interested.
I've been using the prototype for the season so far and it works great.
It's not a breaker bar to break the CL loose right, it is a brake pedal depressor.
I need one. You don't need breaker bars if you have a torque wrench...
Old 08-10-2012, 02:55 PM
DRPM
DRPM's Avatar
Old 08-10-2012, 03:04 PM
kyrocks
kyrocks's Avatar
It's for brake pedal. Works great.
Old 08-10-2012, 05:53 PM
Fred R. C4S
Fred R. C4S's Avatar
Show me the tool, and I'll show you the money!
Old 08-11-2012, 01:18 AM
montoya
montoya's Avatar
I just use reversed Clamps against the bucket seat. Simple, just get the large size with higher clamping force.
http://http://www.acehardware.com/product/index.jsp?productId=2344034&cp=2568443.2568450.2628095
Old 08-11-2012, 06:09 AM
Davis83
7th Gear
Davis83's Avatar
Pm me for address.
Old 08-12-2012, 10:00 AM
24Chromium
24Chromium's Avatar
Originally Posted by Carrera GT
The carpenters clamp works off the seat base and does the job very nicely. Maybe $35.
"IRWIN QUICK-GRIP XP ONE-HANDED BAR CLAMP/SPREADER"
+1
Thanks for the tip, Adam! I too had the "professional" tool for this job and it constantly relaxed and did not hold the pedal down, making it impossible to get the CL nut loose (or tight).
Old 08-12-2012, 07:12 PM
Izzone
Izzone's Avatar
Use the bottom of the seat to rest it against.....problem solved
It still suck because the seal on the slide eventually breaks
I'm currently using a piece of wood, cut to length with a towel on the seat edge.....seat release to release pressure
Old 08-12-2012, 09:19 PM
montoya
montoya's Avatar
Just use the Irwin heavy duty model with 600 lbs clamping force- no issues, I haven't had one fail yet, plus the clamp pads are extra big and help to spread the force on the pedal and the seat, I don't use anything else.
http://www.acehardware.com/product/i...ductId=2344034
I also move the seat back to release the pressure +1
Old 08-12-2012, 11:16 PM
forhamilton
forhamilton's Avatar
I use this and it works great. I just reversed the clamp.
Quick Reply: CL "Braker Bar"
