My Video - GT3 SQS Sequential Shifter, 360 Ferrari Challenge & Evo - Sebring 7.7.12
That is correct...still have to clutch on upshifts. Check out sequentialshifters.com if you haven't already for more info. They quote 6 hour install for qualified tech.
Yup call Gavin or Stephen. Here is there website http://www.sequentialshifters.com Not sure if they fit a cayman. I love the shifter. Aside from being faster, you will never make the 5th-2nd shift like I did. Also, he always has used ones around or can get one. They cost about half as much and are as good as a new one. Good luck.
Thanks for the heads up, I'll be checking it out as I get settled in here.
I am new on this forum, why can I not "quote" a message in my reply. I see the box but am unable to select it
Bottom line is 7k is bit much for the shifter, 3-4k i think its worth it. A gt3 motor is 50k and non-gt3 is about 15k. Its insurance as far as I'm concerned.
How many races do you have with the SQS in your car?
How long are the races?
Whens the last time you had your gearbox refreshed?
I have heard that these SQS shifters EAT through syncro's and it makes sense, the harder you shift through gears, the faster they wear.
Now this shifter in a dog box sounds like a good idea, and you get rid of the syncro issue.
No races so far. First race will be winterfest. In my RS I did about 15 track days with it and 5 in 996 GT3. While I agree its not as hard as true racing I will tell you a beat the living **** out of the car at the track. I have not had the need to refresh my gear box as of yet. The SQS is harder on the synchros but I would not say its eats through them. Shift properly and I'm told there should not be an issue. Ultimately, I'm sure I'll need to deal with it but certainly not every year. I'll update as soon as I get racing.
I hear you. But with all due respect I don't believe it has anything to do with knowing how to down shift. I'm sure the pro drivers are not immune from a 5th to 2nd shift. Sequential is the future of GT racing.
Sequential is the future for sure, but like you said, Sequential. BMW did a sequential I wanna be back in 1997. Basically the same approach.
I'm not really a fan, it has the negative side of the seq. without the positive which is a super fast and clutchless up shift.
It converts the h pattern, synchromesh box to a lever action
I believe a true sequential is different, with dog gears?
You are correct not a true sequential; I also have to use the clutch for every gear change. For me it was more of an insurance policy than anything else. Not sure if I'm any quicker aroud the track but on my traqmate the shifts appear about 50% shorter. Gaurd has developed a true sequential similar to the 997 Cup that they ran in the 24h at Daytona...its 35k. Too much for me so I went with the poser trick mod instead.
