UHaul car trailer with a gt3 - any experience?
Paul, if the issue is carrying the wheels around, I'm sure that we could figure it out. Then you could just drive to the events on your street tires.
I will do Mosport and Tremblant for sure, and then back to Toronto, so let me know if any of this could work. Pretty sure that Trakcar could also fit an extra set of wheels in his rig.
Francois
Thanks for the offer - if you have the space to carry them up that would be fantastic.
The wheels will be at GTek Auto (owner Jack) on Cranfield Road of Bermondsey (DVP and Eglinton).
Send my an email - mail@pauloneil.com (cell#416.294.4973)
Appreciate the offer.
Paul
Paul
I have loaded every nook and cranny with tires now, but we should be depleting inventory fast.
Between Clarke trailer and my trailer, I am sure we can take a binch of stuff for you.
If you can get it back from Tremblant we'll take it with us.
Francois will have access to the trailers at Mosport but also until we leave the 19th from Toronto
So I'm about to make a move from norcal to socal and found this thread since i"m also thinking of renting a uhaul truck with the trailer. I looked at instructions on uhaul's website along with the youtube video. My only question is how come you guys aren't backing the car onto the trailer? U haul says you want the heavy end of the car towards the front to prevent the trailer from whipping around.
For anyone loading a GT3, clearing the front is a beatch. Remove the front lip spoiler and drive the rear of the tow vehicle onto ramps. These will both buy you some additional clearance, but even then you'll still probably need wood to extend the ramps.
I used long 4x4s under the ramps and 6x2 boards under the front wheels to clear the trailer lip. The front lift makes the job easier, but you should have someone guide you on. The trailer is pretty narrow - a NB 997 barely fits. An RS will not fit properly due to the wider rear track.
You don't want to load *** first, because of tongue weight concerns. The center of gravity of our cars is directly over the rear axle when loaded nose in.
I was at uhaul this weekend and I went over and inspected one of these trailers. I'm not sure if they are all the same, but I noticed that the stops on the front of the trailer which are intended for the front wheels to rest against are removable. There would still be a stop remaining, but you can take off the tall section of stop with two bolts and then just put it back on when you return the trailer. This should allow the car to be loaded with the front lip intact. I'm going to do this in a month, so I'll report back.
How about this... I need to go 5o the Bay Area for work next week. Ill drive it south for you. Although a few diversions along 101 into the foothills may happen. I'll be gentle I promise! :-)
