997 GT2/GT3 Forum 2005-2012
Rolling Fenders question?
Old 06-08-2012, 12:01 AM
The Greek
The Greek's Avatar
Originally Posted by senna
Very European!
Whats the Brazilian way? Gift GT3 RS for being a Mr. Mom?
Old 06-08-2012, 12:04 AM
facelvega
facelvega's Avatar
I have done a DIY fender roll on my first track car (Cayman), and do not see anything different with the GT3. I just work on the car for fun – no professional experience or training. There are LOTS of things to consider, different front and rear issues. And after all that, when I was having minor cosmetic work done after an agricultural excursion, I had the fenders re-done professionally.
First, I used this tool from Eastwood. It requires a special adapter for Porsche wheel lug spacing.
Biggest issue in the rear – the joint between the fender (metal) and the bumper (plastic). Plastic does not “roll”. If you successfully roll the metal, it all comes to a stop when you get to the plastic bumper. The fender/bumper joint has a thick flange that cuts into a wider tire. My solution was to use a Dremel to cut the flange back to a minimum thickness, and cut the flange on the plastic bumper as thin as possible. I also caused some cracking in the paint. To reduce that (I learned), you should go very slowly and gradually, and USE A HEAT GUN to soften the paint first.
In the front, there are the same issues, with the addition of steering geometry issues. Unlike the rear, where the wheels stay tucked in the wells, the front wheels can turn. Even if you roll the fender and can tuck in a wider wheel going straight, when you turn the wheel, it will comes out of the well and will hit the fender. There is only so much you can do in the front.
The size wheel you can tuck in the rear also depends on the suspension linkage and the wheel size. You can probably get a wider 19” wheel and tire in versus 18", due to the slant of the wheel carrier.
Old 06-08-2012, 12:08 AM
The Greek
The Greek's Avatar
Originally Posted by sstjohn
Greek pulling out all stops to surpass Izzone. A/C is next to go. Radio stays. Can't drive without Madonna playing.
Steve is on fire lately. I will say Vogue is a good track....
Old 06-08-2012, 12:14 AM
The Greek
The Greek's Avatar
Great tips. I just thought about it. Can I even roll the fenders with the centerlock? I didnt know if there was another method for rolling fenders without attaching the tool to the hub. (No Baseball bats).
Old 06-08-2012, 12:36 AM
TRD0524
TRD0524's Avatar
Back when there were no "fender rollers" all people (and raceteams) were able to get perfect fender roll and even a mild pull with a baseball bat and a heat gun (unfortunately it got a bad rap through the tuner car movement). Be careful with Alumium fenders as they tend to warp easier than with regular steel fenders. Not sure what material the 997 GT3 fenders are. Steel is definitely easier.
Paint tends to chip less when its brand new than when its older, but always be ready for it. It all takes time and heat. The guy rolling the fenders must know what he is doing too (and even then if you really roll the lips flat and pull them out to fit wider tires, small chance of not being perfect).
When me and a friend rolled the fenders on my Skyline GT-R (1994) with front AL fenders, one of the fronts slightly warped. We also got rid of the fender liners as they were pretty much useless (not useless on all cars).
Old 06-08-2012, 12:58 AM
p997s123
p997s123's Avatar
I saw the guys from Sick Sideways roll Mike K.'s 996 GT3 in the pits at Sebring. Might want to ask them if you are going to Sebring this WE.
Old 06-08-2012, 01:55 AM
NJ-GT
NJ-GT's Avatar
The Greek, what do you call RS tire sizes in your narrow body GT3? are you talking front or rear, what tire brand, model and size? You might not need to roll fenders at all.
My 996 GT3 (narrower than a 997.1 or 997.2 GT3) ran 18x10 and 18x12 on 285 and 335 Hoosiers, stock fenders.
Old 06-08-2012, 02:25 AM
rijowysock
rijowysock's Avatar
i have a roller and located in tampa, i have the neccesary high temp heat gun as well (gotta heat up paint so it bends and flexes and then when it cools its perfect forever.
i have the roller shown above, problem is your needing to "flare" the fenders, not roll them. rolling is when the fender is L shaped and you fold it into a U, flaring is when it's already a U shape like ours and you need to tilt that U..
widebody is .5" wider.. it might fit as is... depends on height of car and offsets
center of roller has a hole, and center lock has "stud pins" if u could figure a way to secure roller to the hub it would work...
Old 06-08-2012, 03:30 AM
El Matador
El Matador's Avatar
Originally Posted by deputydog95
What are you laughing at? Pot, kettle, black. I'm pretty certain you two were the inspiration for this.
http://www.youtube.com/watch?v=Xvl3q...feature=topics
Sometimes you have to admit defeat..... No.......Yes!!
Old 06-08-2012, 03:47 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,736 Likes on 2,347 Posts
use the tool and do is SLOW. i mean SLOW, took my mechanic about 1.5 hours per fender. he knows i am ****. zero paint chip, no distortion, you would never know it's rolled and pulled.
i fit 9.5 on front of 6gt3. the rear, you need to cut off the flange at bumper.
get the paint hot and do it SLOW.
Old 06-08-2012, 08:43 AM
The Greek
The Greek's Avatar
I would be looking at 265/35/18 NT01's up front, and 335/30/18's in the rear.
Old 06-08-2012, 08:47 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,665 Likes on 773 Posts
RA1 and NT01 I believe step from 245/40/18 to 275/35/18 that's why I was thinking CUP fenders.
Old 06-08-2012, 08:53 AM
The Greek
The Greek's Avatar
Peter your right....
****. For some reason, I thought I saw them available in 265.
Old 06-08-2012, 09:02 AM
TRAKCAR
TRAKCAR's Avatar
2010 RS
OEM 245/35ZR19 - Front. = 25.7OD 808 revs/mile
Option 19" Hoosier front:
235/35/19 = 25.5 = 815 revs/mile
265/35/19 = 26.3 = 790 revs/mile
OEM 325/30ZR19 - Rear. = 26.6OD 781.48 revs/mile
Option 19" Hoosier exist
18" RA1 NT01
245/40/18 = 25.6OD 812 revs/mile
275/35/18 = 25.6OD 812 revs/mile
335/30/18 = 25.9OD 803 revs/mile
18" R6
255/40/18 = 25.9OD 803 revs/mile
275/35/18 = 25.5OD
345/35/18 = 27.0OD 770 revs/mile
Old 06-08-2012, 09:27 AM
senna
senna's Avatar
Newbie question, 275/35/18 will fit the RS and why is it better than 255/40/18?
Quick Reply: Rolling Fenders question?
