Trakcar The Second Built thread
#152
#155
I need to go on the "Ranger diet"... Ranger school. I lost 34 lbs in 61 days of training.
Ranger (Sua Sponte)
#156
Ok, for whoever likes to know.
Two diets I like.
1) Zone
2) Paleo
15 minutes of cardio Four to five times per week.
****Please consult your doctor first****
#158
Picking up tonight all done:
I think this is it, same as last car:
Setup, corner balance mark all nuts and bolts and alignment marks.
R
Camber arms
Toe links
Trust arm
Inner
Adj sway bar links
Front studs
F
Trust arms bushings
Adj sway bar links
LSD same ramps slightly more lockup under throttle.
2 metal brake deflector
Studs
Gurney flap
CF dive planes
CF Akro
CF Side Gurney’s
CUP lip
Tow hooks
SRP pedals
Floor mats metal rennline
Mirrors and end plates, front bumper paint silver
CS roll bar white
Seat belts door pulls black
Windshield band black + Ceramic tint
PFC front rotors Turbo rear PFC08 pads
Puck holders.
Turbo front scoops
Traqmate + camera in + roll bar protection.
Side muffler delete
Angle back seat and roll bar, put drivers’ seat all the way down and back. Seat spacers in
Thinned foam drivers’ seat.
V1 install
XM radio solution I have not figured out yet. Probably I phone.
Pictures tonight or tomorrow.
R
Camber arms
Toe links
Trust arm
Inner
Adj sway bar links
Front studs
F
Trust arms bushings
Adj sway bar links
Studs
Gurney flap
CF dive planes
CF Akro
CF Side Gurney’s
CUP lip
Tow hooks
SRP pedals
CS roll bar white
Puck holders.
Turbo front scoops
Side muffler delete
V1 install
#162
R
Camber arms
Toe links
Trust arm
Inner
Adj sway bar links
Front studs
F
Trust arms bushings
Adj sway bar links
Studs
Gurney flap
CF dive planes
CF Akro
CF Side Gurney’s
CUP lip
Tow hooks
SRP pedals
CS roll bar white
Puck holders.
Turbo front scoops
Side muffler delete
V1 install
R
Camber arms
Toe links
Trust arm
Inner
Adj sway bar links
Front studs
F
Trust arms bushings
Adj sway bar links
Studs
Gurney flap
CF dive planes
CF Akro
CF Side Gurney’s
CUP lip
Tow hooks
SRP pedals
CS roll bar white
Puck holders.
Turbo front scoops
Side muffler delete
V1 install
Brakes: Modified
Suspension: Modified
Body Parts and Aero: Modified
Transmission: Modified
Exhaust: Modified
Wheels and Tires: Modified
Engine: Stock
You need to break-in that engine, with only 800 miles it must be tight, and if you drive it hard from the start, it will wear out bearings and ring a little faster so avoid it.
Dyno? Scales?
#163
Thanks guys!
Rad; Scales above. Dyno maybe after mancation.
Transmission is still stock, or do you mean LSD?
I think next upgrade is regear the gear box when I put in 4.0 clutch and RP.
I'm going to PBIR at 5PM to break it in, just short shifting it a bit but I am sure it has been revved up before.
Saturday again to PBIR and change oil again perhaps, after that I consider it broken in.
