997 GT2/GT3 Forum 2005-2012
Cup lip attachment problems?
Old 04-04-2012 | 04:44 PM
TRAKCAR's Avatar
TRAKCAR
I think that is how they go on CUP cars. They do not come with clips as far as I know.
orbit added them and added that CF piece but you do not need it, it will not fall off.
Sometimes they pop put if you scrap it a lot (In the middle and somehow that pops ou the sides.), I just walk by and kick it back in place.
Old 04-04-2012 | 04:46 PM
Larry Cable's Avatar
Larry Cable
Originally Posted by TRAKCAR
They are not exchangeable.
Old 04-04-2012 | 04:48 PM
TRAKCAR's Avatar
TRAKCAR
.1 VS .2 lips.
Old 04-04-2012 | 04:54 PM
Larry Cable
I just took a look at mine (sitting in the garage) and I see what you mean ... since its a cup part I think it is intended to attach to the cup front wheel arch gurneys (as in trackcar's pictures) ...
only thing to do is (a) leave it as it is, or (b) drill a small hole thru the adjacent black plastic and zip tie it ... or perhaps (c) get some double sided tape and tape the splitter to the underside of the bumper
Old 04-04-2012 | 04:57 PM
Larry Cable
.1 VS .2 lips.
RIGHT! ... looking at your pictures do you have the cup cars front wheel arch "gurneys" installed?
Old 04-04-2012 | 04:58 PM
TRAKCAR's Avatar
TRAKCAR
yes, helps to stop the CUP car lip from flapping about.
Old 04-04-2012 | 04:59 PM
Larry Cable
where did you source those from?
Old 04-04-2012 | 05:01 PM
TRAKCAR's Avatar
TRAKCAR
Orbit put them on, last time my car was in the shortened them so they stop right below the corner lights.
Before they went past the corner lights, not sure why but maybe it is easier to take off the front bumper to cclean out the ducts etc..
Old 04-04-2012 | 05:04 PM
Larry Cable
I wonder then if it makes sense to fit a cup splitter w/o those also? given that there is no support against wind pressure at either end of the cup splitter w/o them in place and screwed together?
Old 04-04-2012 | 05:08 PM
Larry Cable
yeah you can see them (just) in the Porsche cup car gallery on the website ... they appear to go to the point at which the bumper meets the body, because of course the cup does not have the side markers so I can see why orbit would cut them short or an RS
Old 04-04-2012 | 05:25 PM
atleung's Avatar
atleung
Zip ties through the holes that don't line up perfectly.
Old 04-04-2012 | 07:32 PM
gt2urbo's Avatar
gt2urbo
a bit off topic but why are these front lips so brittle? i break mine almost every time im at the track. from very mild offs to touching the candy canes... i have 10 in supply at all times just in case. this consumable is getting to be pricey. LOL anyone have any leads or a different front lip idea?
Old 04-04-2012 | 07:33 PM
TRAKCAR's Avatar
TRAKCAR
The Cup ones are unbreakable. I'm still on the first one??
Old 04-04-2012 | 08:46 PM
SSTHO's Avatar
SSTHO
Agreed. I scrape more than 50% from my condo driveway each outing and no cracks. It does not protrude as much as the OEM one and it feels softer too.
Old 04-04-2012 | 09:06 PM
Larry Cable
Originally Posted by 9972RS
How do you guys attach the cup lip spoiler to the 2010/11 GT3RS? There are two pre-drilled holes on the cup lip, but they don't line up to anything on the RS.
Did you guys just drill another hole?
I think since the stock splitter attaches via a screw underneath the bumper just in front of the wheel well, I would be inclined to drill the cup splitter in a similar fashion and secure it accordingly ... at least that way its attached by screws, you could add zip ties to the current holes also ...
Quick Reply: Cup lip attachment problems?
