Dealer says Porsche redesigned coolant fittings for 10/11 GT cars
In my dreams this is true. Unfortunately, members here as well as Alex from SW have documented .2 coolant pipe failures.
Also picking up bag o corn.
He said the pn was different in PET from 09 forward.
For those that have done TIG welding- the question was raised as to whether anyone has looked at using the welding material used on aluminum AC lines as in residential use. Those lines apparently have much higher heat and pressure than the coolant lines in our cars. I don't know about welding.
Thanks for this Scott.
Now, if this is correct, OVR should accept this explanation, and therefore not demand for 2010/2011 cars to run with Water Wetter, or to have the couplings pinned or welded, correct?
May I recommend that you submit this to your region, and see what they say
My chief instructor who has an 04 GT3 will be there Sat. Will talk with him.
I may just run water wetter.
I have a 997.2 ('11) GT3 and had a coolant pipe burst at 2000 miles. However, this was not at the fitting, but rather in the plastic seam of a pipe near the front right wheel. No problems since repair.
Pass the popcorn please...
I was hoping to drive my new RS 4.0 at OVR events this year. I'm not sure what I think about all of this, now. Maybe something convincing will turn up at or before the March 3rd OVR Ross Bentley high performance driving seminar in Dayton.
Mike- just bring the CGT to our event in April . Saw it yesterday- still looks perfect!
Got this today...
OVR COOLANT LINE SAFETY NOTICE UPDATE
It appears that Porsche has quietly addressed the issue of the coolant lines coming unglued from their housings in GT1 type engines. The housings have been re-engineered to increase the bonding surface area of the tubes and a new, high-strength/heat-resistant bonding material is used. We are hoping that they can tell us when they started using these new parts but unfortunately at this point that information is not available. It does appear that 2010 and later GT3 RS’s have them so one would assume that this would include the Turbo’s as well. *
Based on this, we will exempt these cars from the requirement that they MUST either run water with Water Wetter in their coolant systems or mechanically secure these pipes. However, unless your dealer advises against it, we strongly encourage the use of distilled water and Water Wetter. In fact, Porsche of the Village is offering a program where they will drain and capture your coolant and store it for you for future use. Then flush the system to remove the remaining glycol coolant then refill it with distilled water and Water Wetter for approximately $200.
We also want to caution owners of earlier cars that the fitting located behind the power steering pump, which has been the main problem, is not the only one that can fail. There are ones behind the alternator that have failed as well. Therefore, if you are addressing this problem by welding or pinning these fittings, you must do all of them. Even after this has been done you are still encouraged to change over to the distilled water with Water Wetter for track use since hose failures can also occur.
Please feel free to contact us if you have any questions,
