997 GT2/GT3 Forum 2005-2012
Brembo Slotted Discs/PF pads query
Old 02-14-2012 | 01:48 PM
1198r's Avatar
1198r
Default Brembo Slotted Discs/PF pads query
Have had the front discs replaced with the lovely Brembo slotted along with change of pads to PF. Not tracked car yet (this Friday) but have noticed the ABS cuts in a lot more when I have had brake heavily (not track heavily) on road. Anyone experienced this and is it likely to be the same on the track?
Old 02-14-2012 | 02:03 PM
TRAKCAR's Avatar
TRAKCAR
I felt no difference anywhere with PFC08 pads, rotors should not matter. Should be the same!?
Tires old?
Old 02-14-2012 | 02:18 PM
On Pole's Avatar
On Pole
Your tires are most likely the issue. More grip is needed.
Old 02-14-2012 | 02:45 PM
1198r's Avatar
1198r
MPSC done 2500 km, no track days and lots of tread left.
Old 02-15-2012 | 03:09 AM
BBMGT3's Avatar
BBMGT3
You have just switched from Trofeo to MPSC. MPSC has less grip, you can't pull off the same stuff.
Old 02-15-2012 | 04:03 AM
1198r's Avatar
1198r
after my experience with trofeo - never using them again!
Old 02-24-2012 | 01:27 AM
paver's Avatar
paver
1198r, I'm about to put PFC 08 pads on with type III slotted Brembos. Are you having good luck with that setup? Did your car initially have PCCB? If so, what are the part numbers on the PFC pads you used?
Quick Reply: Brembo Slotted Discs/PF pads query
