997 GT2/GT3 Forum 2005-2012
Non-RS GT3 Track Tires?
Old 01-24-2012, 09:44 AM
drdrank
drdrank's Avatar
Originally Posted by kyrocks
I use Hoosier R6, 315/30/19 in rear and 235/35/19 in front. When I don't trailer (since 2 tracks are withing 45 minutes of my house) I use MPSC 305/30 and 235/35 in dry and same sizes of Super Sports in wet.
Do you like those Super Sports in the wet?
Old 01-24-2012, 11:42 AM
utkinpol
utkinpol's Avatar
it would be great if anybody with 997 gt3 car could finally conduct this experiment with 275/315 NT01 tires and confirm if they do indeed cause any PSM/ABS related CELs or odd behavior or do not.
Old 01-24-2012, 12:23 PM
drdrank
drdrank's Avatar
The Greek has a 997.2 GT3 and is running NT01s. Not sure what size. Maybe ask him.
Old 01-24-2012, 12:28 PM
Mvez
Mvez's Avatar
Even if they do work fine, which has yet to be confirmed, I prefer more sidewall than the 315-30's give....ideally a 305-35 or 315-35 would be offered. More grip, more progressiveness, better handling.
Nitto is looking at adding these sizes, we need to keep harassing them for the 35 aspect ratio.
Old 01-24-2012, 12:29 PM
NorthVan
NorthVan's Avatar
Why do you want to run such a wide front tire? I never had excessive understeer on my C2S. What am I missing?
Old 01-24-2012, 12:33 PM
utkinpol
utkinpol's Avatar
with all due respect, i`ll beleive it when i`ll see it...
Old 01-24-2012, 12:36 PM
utkinpol
utkinpol's Avatar
understeer, probably.
cup cars run practically same sizes in slicks, 280/320. ther is nothing wrong with wide front tire, at all. i tried my car with 245/335 once - it was undrivable no matter how i tried to adjust setup, and nittos 315 tire is almost as wide as RA1 335. i balance my car to the limit where it slides on all 4 points in the sweeper as i push it with throttle, with just a bit of understeer.with 245/335 i could not do it, with 245/305 it did not have nearly enough grip in rear, 275/335 works perfectly fine.
Old 01-24-2012, 12:48 PM
NorthVan
NorthVan's Avatar
Typically Cup cars run 240/640/18 fronts and 280/680/18 rears, but it depends on the series.
Old 01-24-2012, 12:50 PM
utkinpol
utkinpol's Avatar
240/280 is on 9/11 rims, for 10/12 or 11/13 - 280/320.
if i will get annoyed enough this season with my front axle i will replace my front rims to some wider ones as 275 tire on 9" rim is not optimal. 265 tire would be better but NT01 does not have it, nor 255.
Old 01-24-2012, 01:02 PM
NorthVan
NorthVan's Avatar
"We run these on the 2010 Cup with 9.5 fronts and 12 rears."
This is a quote from a major team, as well they post on RL on a regular basis.
Old 01-24-2012, 01:17 PM
Mvez
Mvez's Avatar
305 is more than enough tire for the rear.
Old 01-24-2012, 01:48 PM
The Greek
The Greek's Avatar
I am actually running NT01 245/40/18's upfront, but 305/35/18 rear in RA1's.
Finding RA1 fronts is impossible, so this was the best alternative. Tire grip is very close. No problems with ABS or PASM.
Old 01-24-2012, 02:04 PM
TRAKCAR
TRAKCAR's Avatar
Received 1,651 Likes on 767 Posts
I don't know about heat cycling, but I corded them as quick as Hoosiers.
As soon as profile is gone, they have zero grip and cord immediately after.
So to me it's Hoosiers if you cant make Nitto's or RA1's work.
Old 01-24-2012, 02:22 PM
utkinpol
utkinpol's Avatar
not all 305s are same. like in NT555r2 305 tire is 12.48" wide (almost 315 dot), nt01 315 tire is just 12.6" wide but has shorter stiffer sidewalls. ra1 335 tire i have now is 26" tall and is 13.3" wide. so it is an inch over 305 tire and 0.3" shorter.
then you look at 245 width - 9.72" compared to 275 10.9" and look at ratios you want to have on your car. 240/280=0.85, 280/320=0.875.
so we can presume for 2" split between front/rear rims in width we would want somewhat close to 0.86 ratio between front and rear tire width.
that was my logic, anyway, and that is how 275/315 in NT01 lineup gets binded together nicely as itis quite close to that.
if you go with nt01 245 tire in front then you need 287mm wide tire in rear to stay within target ratio and there in no such tire in nitto lineup, 305 tire is 316mm, it will be 0.78 ratio.
Old 01-24-2012, 03:49 PM
997gt3north
997gt3north's Avatar
Originally Posted by 911GT3
What series in the Hoosiers? I see there is an R6 in 315/30 for the rear, but for the front are you running a 35 series, i.e. I can find a 235/35--is that it?
yes
- 235/35/19
- section width is 10.2 inches - i.e. 259mm - i.e it looks and is wider than a 'normal' 235 tire
- the actual tread width itself is 9.3 inches or 236mm
- 'they say' optimally you want the rim width from a maximum contact patch perspective to be basically the width of the actual tread to possibly slightly larger BUT this tire does absolutely fit on a stock 8.5 width front rim
I had pro David Empringham drive my car with a set of new R6s (235/315 in 19s) and he said the car was perfect - the speed he took me around Mosport with these tires was insane - 2:32 with me in the car
http://www.tirerack.com/tires/tires....R9R6&tab=Specs
Quick Reply: Non-RS GT3 Track Tires?
