Removing brake pad sensor wires???
Replacing stock pads on my PCCBs, but don't know how hell to pull the sensor wires from the pads. There is a short red wire that connects both pads, and then a black wire on the inner pad that leads toward the car. On the pads the wires run into a little wire clip thingy, and I thought the wires would easily pull right out. Not so.
I will not use sensors on new pads, so what do I need to do with the free wire once removed from the pads?
Thanks!
Thanks!
Ok, i tried harder and they do pull right off the pads
Now what do i do with the free wire? I am not using sensors on new pads. Its ok, talk to me like I'm 8 years old - i have never done this before!
Yep, sensors are fine - never activated.
Pads are fine too actually. I am swapping them now only cause I have 4 day coming up essentially back to back and not sure they would last or all 4 days.
Awesome - thanks guys.
Here is sensor wire. You just zip tie this whole thing, or trim red-sheathed portion, then zip tie? Or no matter?
All my questions notwithstanding....the whole process was painfully easy. And it all went well, aside from dropping my reservoir cap deep into the innards of my car..... Now I need to begin dismantling the plastic bits in the boot in search of it. Ugh.
If you trim the wire you will have to replace the sensor wire if you ever choose to return car to stock (with sensor) in future (eg trade in etc.)
OK, now I am off in search of my damn reservoir lid!
I have removed all the screws holding the plastic covering that surrounds the reservoir, etc, but it is still attached at this point (see photos).
What is this thing? I am pulling and pushing on it in every direction but it appears to have no function, but it is holding the plastic cover in place. WTF?
Definitely not what I wanted to spend my time doing today....
