Need help removing luggage compartment trim piece
I found a small amount of brake fluid under the emergency air compressor in my gen 2 GT3. I'd like to remove the trim around the brake fluid reservoir and master cylinder to see what's going on.
I took out 8 T10 screws but the tab thingy at the red arrow is still holding it in. Can somebody tell me how to get it off?
If you track your car (and maybe if you don't, just drive on rough roads...) you will often "spit" brake fluid out of the breather hole on the reservoir. You may have a nice puddle of brake fluid at the bottom of your frunk (I did), slowly dissolving the paint.
I took a hint from what I saw the cup guys do (super high-tech): Get a cotton wrist-sweat-band. Put it on the lid to the resrvoir with a rubber band. When it gets saturated, throw it away and put another one on...
The fluid comes out of the lid on the brake reservoir. I thought there was a vent on it, but I cannot find one. I guess it must leak around the edge seal?
Frunk top view with wristband on reservoir:
Reservoir top view:
I just know that with nothing on the reservoir lid, I have a brake fluid puddle after every run session. Put the wristband on the lid - no puddle. You can see that the reservoir is INSIDE the sealed trunk area. If your mechanic misses the reservoir while refilling, all the fluid goes to the bottom of the trunk, no drain holes, so it stays there. There are drain holes around the battery and the outer perimiter of the trunk, but inside it is sealed, so all brake fluid stays inside (pooling on the paint).
I have the frunk empty (as seen in the picture) so I can see immediately if I am losing fluids. I was freaking out, thinking I had brake problems, until one of my coaches (cup driver) told me it was just a reservoir leak, that all the cars have it (when driven hard) and how to deal with it. Since then, always dry as a bone....
Reservoir top view:
Reservoir top view:
Reservoir top view:
Center Black cover for fuel tank stuff (pumps, etc).
Left Big black box - carbon cannister to allow fuel tank to breathe without polluting.
Small black box on left wall: front trunk electrical control unit (controls lights, locks, turn signals).
Below that, silver box - it is the amplifier for the stereo.
