Jack point jackstands and Rennline tie down/jack plate - who is using this combo?
I love my jackstands and Rennline front tie downs, but every time I jack the car I am taking off the front Rennline tie down plates to accomodate the jack plate. This is turning out to be a PITA cause I have to unscrew a portion of the plastic under tray as well to remove them.
Any body using this combo have a better solution???
I jacked my C2S in the rear most of the time and took the entire side of the car up at once. If I just needed to work on the front, I would put the jack right under the tie down
Did you ever use the jackstand/jackplate under the front tie down?
My issue is that I work on the car here and there - don't usually have time to get everything done in one session. So, I'll put it on the stands and sometimes leave it there for a week, and so I want it to be super solid on all 4 corners.
Maybe it would work just fine - I have never actually tried it. Again, if it were just for an hour or so I wouldn't stress too much, but it makes me nervous leaving it like that for days.
I can't recall where I put my jack stands when I put them up front. I would imagine somewhere in a little deeper where the suspension meets the frame.
I will look when I get my GT3 (in the next day or two).
I've been using this combo, without issue. I'm not taking my tie down's off. I lift the car at the rear jack point. The car will be high enough to slide the front jack point stand under the front. I then lower the car, just making sure the bolt is in the center of the jack point plate (minus the pin). Then repeat for the other side.
If the car is solid for an hour, it'll be solid for a week, a month, or a year.
I don't always know owners by RL screen names, but I believe Mojom3 had two pads drilled with 1" diameter holes instead of 5/8". That can be done if you already have the pads in hand or before shipping if you're sure you need the larger hole.
