997 GT2/GT3 Forum 2005-2012
Odd Toyo Wear
Old 11-21-2011, 10:11 PM
mdrums
mdrums's Avatar
Default Odd Toyo Wear
The inside of my Toyo R888's looks really odd. My last set started doing this on my 2009 Carrera S in 18" sizes and now the 19" tires on my Carrera GTS are doing this but worse.
I showed this to my local race shop and they said they've seen this recently on Toyo R888's and I saw this happening on Deputy Dog's R888's he uses for street tires. So this is not just my car.
I had my string done alignment checked and it is right on spot on
FRONT
-2.5 camber per side
.5mm toe out per side
REAR
-2 camber per side
2mm toe in per side
Old 11-21-2011, 10:14 PM
sin911
sin911's Avatar
That's interesting. My RA1's are getting even wear though I drive from Miami to Sebring
Old 11-21-2011, 10:25 PM
997gt3north
997gt3north's Avatar
That brings back memories - not really sure what was happening - I thought it may have been showing where the tire got hot to track temps, kinda liquified so to speak, and then re-harded - chemically different - that was my own stupid explanation.
You need to back down the camber on those tires - very hard sidewalls - that inner edge will cord and you will insta hit the wall - please remember this!!!!!!
Try -2.2/-1.7
Old 11-21-2011, 10:58 PM
mdrums
mdrums's Avatar
Try -2.2/-1.7
I was thinking of backing down the camber....how ever I'm probably going to get a set of MPSC which I here like more camber....I'm going to the Michelin site now to see what they suggest.
Old 11-22-2011, 12:12 AM
acadian_dad
acadian_dad's Avatar
Those look very similar to my RE11's that I just corded at the last DE. These photos were taken just before they corded :
Those lateral grooves used to "wrap" around the shoulder ... I'm guessing its too much neg camber but not sure.
And after ...
This was on a 997.1-S cab, stock rear suspension
-2.3 deg camber
+0.19 deg toe
Oh yeah - just remembered these RE11's didn't have the correct load rating comparied with PS2's, etc. So maybe the inner sidewall was collapsing under some conditions.
Old 11-22-2011, 01:30 AM
mdrums
mdrums's Avatar
Yeah -2.3 is too much in the rear.
Old 11-22-2011, 09:10 AM
Spiffyjiff
Spiffyjiff's Avatar
mine are doing something similiar albeit not as severe. i thought thin patches like that on the inner edge was a result of excessive toe...? (i.e. if the wear patch is wider/approx half the tire width, then i thought that meant excessive camber, etc)
Old 11-22-2011, 09:21 AM
AudiOn19s
AudiOn19s's Avatar
driving to and from the track on them?
I had a set of R888's do that on my old 996. Sadly our cars like a good bit of toe in at the rear and some toe out at the front, combined with the proper camber values it's pretty hard on the inside shoulders driving in a straight line.
I left the track once maybe 5 minutes after coming off my last session, nothing cooled down and drove directly home 45 min on the freeway. The next day when I switched back to my street tires I noticed a blister on one of my rears on the inside sholder area where you are having your issues. I attributed it to leaving on already hot rubber then driving 80mph for 45 min in a straight line which is already hard on them to begin with. I try to not drive to and from the track on my track tires now if I don't have to. Did it a few times with the GT3 on PSC's this year and they were fine though.
Old 11-22-2011, 09:47 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,660 Likes on 771 Posts
My RA1's do that also on the inside of the least used tire, so at Sebring the right inside rear wears like that, while the left rear outside wears more then the inside.
Maybe the car just leans too much or maybe too much flex in the rubber stuff. Izzones tires wear a little better with some hard bushings, I might do the same if it continues to be an issue of tire wear with 5/32 shaved still. with 5/32nd I hope there is anough rubber to get them worn down even, it was a bigger issue with the 2/32nd race ready shaved ones.
Old 11-22-2011, 10:07 AM
Erik
Erik's Avatar
another suggestion besides the camber is the rear tow arms, if stock, or worn, this will also happen
Erik
Erik's Avatar
toe
Old 11-22-2011, 10:39 AM
Izzone
Izzone's Avatar
+1
The best money saving mod I have done......
Tarrett
Toe arms
Dogbones
caster puck
bearing
It has taken all of this wierd wear away
Mike......for what it is worth, Peter and I have found we have to run less camber with RA1 than we uswe to with a NB GT3. 1.6-1.7 is perfect
Old 11-22-2011, 10:46 AM
The Greek
The Greek's Avatar
Randy, is that front or rear camber? I run 2.2 Front, 1.7 Rear
Old 11-22-2011, 10:50 AM
Izzone
Izzone's Avatar
Rear
Nick your car is like mine......our car holds alignment under load due to solid mount. Our settings are hard to compare to a rubber mount rear car
Old 11-22-2011, 10:59 AM
TRAKCAR
TRAKCAR's Avatar
Eddie tried expalining it to me.
What part is the rubber mount I still have but you don't that makses the car set quicker and wears tires better?
Quick Reply: Odd Toyo Wear
