Car will not start from first attempt
These days my 2010 GT3 most of the time will not start the engine from the first attempt. Means when I press the clutch and the gear in nature and turn the ignition, all cluster lights will work but no ignition. Sometimes if I waited for 3-4 seconds the ignition will start and sometimes not and when I return the key to 0 to restart I got depress the clutch.
Have any of you faced such a case
faulty clutch switches have been a problem on the 997s.
if you are stranded, it is the switch closest to the clutch pad.
there are 2 wires going into the switch, take those out of the switch, and use 1 wire to bridge the
2 connections in the switch.
THEN MAKE SURE THE CAR IS IN NEUTRAL WHEN YOU START...or she will fly!
