Brake disc thickness
A good visual sign is when the cracks go all the way to the inner or outer edge of the disk. For a 32 mm disk, usually the minimum thickness is 1.0 mm from the starting thickness. *Example: 0.5 mm minimum thickness on left and right rotor cheek*. Has to be checked with a digital caliper. Good place to check on a rotor is the middle to outer edge.
Most people replace because of cracks before wear. However, if you look at the oem disc there are a few holes (actually dimples) on the edge which are not drilled thru all the way.. They are wear indicators. When the dimple disappears, the rotor is worn out.
