997 GT2/GT3 Forum 2005-2012
PFC08 Brake Info
Old 01-06-2012, 05:13 PM
  #106
Mvez
Mvez's Avatar
Originally Posted by Carrera51
Mvez:
The APs for the 997.1 GT3 take the Pagid 2707 so the PF0991 would work since it's the same shape.
Some information on the PF rotors for the 997.2 GT3 and GT3RS:
The race rings are narrower as there are no provisions for the anti-rattle bevel springs/rings, as on the street type rings. The race rings are lighter and are full floating. The street rings are broader to support the bevel springs and therefore quieter for the street. Both are suitable for track day use. Also, the current hats offered by Performance Friction have round holes for the Porsche drive pins. The old style hats with the oval holes are no longer produced. All the hats we have are the current version produced by Performance Friction.
Slotted discs offer more bite and clean out a little better than the dimpled discs. The slotted discs are noisier and not recommended for the street. In the case of the race discs, they are lighter as they are 32.0mm thick (20.3 lbs) vs. 34.0mm thick (23.3 lbs) for the front dimpled discs. We weighed both on our UPS scale, while still in the boxes. The 34.0mm should have more thermal capacity so therefore should last longer.
The slotted race rings and hats are sold separately, not together as a kit like the dimpled. The slotted rotors are 378x32mm, the dimpled are 379x34mm. Performance Friction says to use the PF7819 pad with the 378x32mm slotted rotors. You can use either the PF0991 or PF7819 with the dimpled rotors.
We have stock in house of both the 378mm slotted (along with the hats) and the 379mm dimpled, along with plenty of the PF0991 in 08 compound, and PF7819 in 08, 06, and 01.
Hope this helps.
Thanks! Sometimes I honestly get tired of the pad knockback from the full floating "race" discs on my M3 (some of that is in part to the Stoptech ST40 caliper design, to be fair). If I was in the market for PFC rotors for the RS, I'd spring for the "street" PFC's, as most of us DE'ers could make much more use of the higher thermal capacity as opposed to the slightly lighter weight. More fade resistance and longer service intervals are two things both I and my wallet, most certainly appreciate.
Old 01-06-2012, 08:26 PM
  #107
TRAKCAR
TRAKCAR's Avatar
Received 1,670 Likes on 775 Posts
What's pad knock back?
Old 01-06-2012, 11:36 PM
  #108
Izzone
Izzone's Avatar
When the pads are knocked back....duh
Old 01-07-2012, 12:03 AM
  #109
Carrera51
Carrera51's Avatar
Here's a nice explanation of pad knock back:
http://www.stoptech.com/technical-su.../pad-knockback
Old 02-10-2012, 04:16 AM
  #110
Schaffer
Schaffer's Avatar
Originally Posted by mdrums
Wish PFC made 08's in these Porsche fitments! These fit 2002-05 996 Turbo and 2005-2012 Carrera S (997S) and some older Cup cars and fronts of some Boxsters.
7818.xx.17.44
0776.xx.17.44
I think they are looking into these pad shapes amonge some other older ones according to their European office.
Anyone having experience of using PFC 08 on PCCB??
Old 02-10-2012, 01:52 PM
  #111
Carrera51
Carrera51's Avatar
Schaffer:
Our rep at PF has told us that the 08s in the 7818 shape are special order here in the U.S. We have ordered the requisite number of sets and should have them in stock in about 3 weeks.
As far as using pads not specified for PCCB rotors, I haven't heard of anyone doing it. I know of several people who have removed the PCCBs and are running the Performance Friction rotors.
Old 02-10-2012, 05:17 PM
  #112
gt3'er
gt3'er's Avatar
Mark (OG) or Clark (APEX),
Can you guys confirm a statement above indicating PFC rotors are good until the slots (or dimples) are gone? I have PFC floating slotted rotors (with anti-rattle bobbins) and they have significant cracking...but otherwise smooth...can they wear all the way down till the slots are gone, regardless of cracking?
Thanks!
FR
Old 02-10-2012, 05:19 PM
  #113
M3EvoBR
M3EvoBR's Avatar
as long as your crack don't go to the edges, you're fine.
Old 02-10-2012, 05:33 PM
  #114
Carrera51
Carrera51's Avatar
They can wear down till the slots or dimples are gone. But, if there are cracks out to the outer edge, or inside to where they attach to the hat, it is time to replace. How many days do you have on your rotors? Can you post a photo?
Old 02-10-2012, 05:39 PM
  #115
gt3'er
gt3'er's Avatar
I will post a pic and track days - asap, but may take a couple days...car is stored in rented garage across town...
Appreciate the feedback...
Old 02-13-2012, 04:12 PM
  #116
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
Question: What is THE preferred PFC pad compound for the 997.2 GT3?
Old 02-13-2012, 04:17 PM
  #117
TRAKCAR
TRAKCAR's Avatar
LOL, you read the thread?
PFC08 seems to do pretty will
Old 02-13-2012, 04:19 PM
  #118
TrackDays247.com
Former Vendor
Oh I did. PFC 06 also seems to be a favorite, but the 08 appears to have surpassed it.
Old 02-13-2012, 04:45 PM
  #119
TRAKCAR
TRAKCAR's Avatar
Out with the old, in with the new ;-)
I have never tried PFC06, but 01 to aggressive for my taste and I am so happy with 08 I don't want to try anything else.
Old 02-15-2012, 03:56 AM
  #120
drdrank
drdrank's Avatar
I switched from RS29 to PFC08...now all of my braking points are a good 50 feet to early!
Quick Reply: PFC08 Brake Info
