Torque Solution GT1 Engine Coolant Pipe Fix..
Torque Solution has brought to you an 8pc Coolant Pipe Repair Kit for all Porsche Gt1 Engines with Press fit and Glued coolant pipes.. These will fix the issue that plagues the Gt1 engine of water pipe failures resulting in coolant dumping all over the engine bay and possibly on to the rear tires causing you to lose control of the car. This issue can ruin a good track day weekend or even worse cause you to have an accident on the street or on the track.. If you have your engine out of the car for any reason thats the best time to do the repair.. This will require the engine to be removed and the fittings welded in place.. Giving you peace of mind knowing its done right with the weld on fittings..
195.00 Shipped
195.00 Shipped
![](http://www.torquesolution.com/v/vspfiles/photos/TS-POR-001-2.jpg)
"I opted the tig weld all those glue joints. What a pain in the *** getting all the glue off so you can weld with out getting porosity."
195.00 Shipped
195.00 Shipped
What's the fabrication of these fittings -- are they billets machined to the application?
What's the alloy -- is it the same as the factory?
Is the wall thickness the same as the factory?
I assume it's the skirt that's got more meat for the weld. Do they require the weld to seal or just for mechanical strength? The welding job is very tight, so if it could be done with just stitches, it might be less error prone (less likely to damage one of the factory castings.)
Mike
They are machined to fit the gt1 specifically..I dont know what the factory alloy is but these are 6061 Billet.. These have a thicker wall thickness.. they MUST be welded to seal they cannot just be pinned.. Hope that helps answer some of your questions..
Mike
Mike
I was thinking of a different sealant, not a pin. I think three stitches and an appropriate work/temperature sealant is one solution. For my own needs, I've been working with a local shop on a mechanical solution (instead of a pin or a sealant alone) but not everyone will have access to the tools necessary.
