I heard about his car, but I don't know about the set up. Do you mind share about it ?
Have to weigh it as soon as I get transmission back from Brian Copans (7 weeks now and counting, all re-geared, and of course 2wd). Should come in about 2700 lbs, maybe a tick less. X51 motor with K24s made into hybrids. External wastegates and straight pipes off turbos. Motor has the 997GT2RS intercoolers with intake straight into turbos. Custom y-pipe, 78mm throttle body and intake, and a special sauce mod to give car lots of extra RPM and top end HP and torque. Suspension is all monoball/adjustable arms with solid bushings on rear suspension cage. There is a lot more, but you get the idea....
Ok y'all mentioned the cup lip, but you forgot the time certs, toe links, track exhaust(big weight loss), radio delete is good for a second
Time certs....added weight
Track exhaust......just a noisemaker to **** off Erik when I block him
Toe links.....no advantage, i just hit too many curbs to keep an alignment more than a week
Radio Delete.....Ok you have me there
I'm gunning for Randy next since he's the slowest gazelle (relatively speaking) is the FL Rennlist Super Solo herd. Now I just need to figure out how to take four more seconds off
Trust me, sub 2:30 is not that hard.......each second below 2:30 is harder and harder to get. The hotter it is out.......it gets even harder
