Track tire pressures for 997 GT2
This is the most basic question in the world, but I'm not finding a direct answer with a search of the forum (could easily be my searching skills), but I would sure appreciate input.
I'm running my 2008 GT2 on the track this weekend on the OEM MPSC tires and am wondering what I should aim for as a hot tire pressure front and rear.
Thanks!
Thanks!
From Michelin: http://www.tirerack.com/tires/tirete...nd_Feeding.pdf
Hot front/rear: 32psi/36psi
Camber: -1.5 to -3.0
Temps: 160 - 220F
Temps: 160 - 220F
I have a 997 GT2 which I track a lot. I find that 33 front and 35 rear hot works very well. I usually start the day at 25/27cold and have to bleed some air after the first run group and later in the day as the temperature picks up. Good luck on your track day. Remember to get the car pretty straight before mashing the gas.
