Cayman R Weight vs. GT3
it's the roof bit that they don't share. and that's what delegates the spyder to a weekend car. you can't park that anywhere in sydney - the roof will get knifed. also, not the best decision to track in a cabrio. the cayman r has none of these issues. like somebody said, it would make a great entry-level for somebody's first porsche, that will encompass mostly dd + local test loops + mid-range tracking.
an all-purpose car without hurling yourself over the slope.....till later.
![cherrsagai](https://rennlist.com/forums/graemlins/drink.gif)
IMO the weight savings on the R is not impressive; most of it is just from the AC delete and stereo delete and smaller gas tank, they really didn't do much. The good thing about the R is that they have actually delivered a properly set up Cayman from the factory for the first time without horrible understeer dialed in.
let's not be mistaken here. the cayman r will be MURDERED by the gt3 on the track. it would be very close on a test loop on public roads, but on track, it's a whole different ballgame.
Nice data, but it looks like you had the stock PASM suspension ? The Spyder/R suspension is much better for the track, a bit closer to a GT3. Also the new DFI engine is a lot better than the last one.
Just spent two days at the Chin Road Atlanta DE. On the track was a brand spanking new white Caymen R with sport buckets, PDK and ceramics. Looks better in person than I anticipated. It was flat out fast, not just quick or able to hold more speed in the corners. On the long back straight between turn 7 and turn 10A the Caymen was a handfull. I ulimately had more top end speed, but it was remarkably fast compared to my 997.2 GT3 and always held its own through at least third gear. In a capable drivers hands, it won't get murdered by anything.
of course! (i'm comparing to boxter spyder here, if you are talking gt3, then there is definitely no comparison)
Car and Driver Lightning Lap Times:
http://www.caranddriver.com/features...to_2011_page_8
997.2 GT3 RS: 2:55.9
997.1 GT3: 3:01.8
Boxster Spyder: 3:03.8 (the Cayman R should be about the same)
997.1 GT3: 3:01.8
When comparing lap times, keep in mind the very significant difference in OEM tires between the GT3/GT3RS and the Spyder/R.
Check out this laptime at Hockenheim for the Cayman R (only 2.0 sec slower with Street tires compared to 997.2 GT3's time with DOT track tires) and it's faster than the 460hp 996 GT2:
http://www.fastestlaps.com/tracks/hockenheim_short.html
The Spyder on the other hand is down right sexy, a blast to drive on the open road but not really set up in OEM form to be a great track car.
I'm glad I have one of each, modding my GT3 helps me leave the Spyder in stock form, it's more than enough car for street use.
