Clicking noise on RS
When I drive 15 miles an hour in a tight circle, I get a rapid click-click-click noise that changes with speed. I can turn in a wide circle and it takes a higher speed to replicate the noise. Wheel lugs are the properly torqued. This noise is new.
Any ideas?
Any ideas?
Yeah, I saw that thread....lots of theories and no definitive solution. Last post was in January so I thought that I would start over. Has anyone out there figured this out for sure. Is it wheel torque? (mine are at 350, done properly in the air) It is the fuel line? the wheel weights? I am running stock wheels...so there is all kinds of clearance!
My RS clicked with the first set of tires. Corner workers even heard it on the track.. It was loud enough that they reported it. I wore out the first set of tires and mounted a new set. Never heard the click again. I know it's not definitive, but it seems like remounting the wheels may cure the problem.
I took the wheels off and greased the parts as instructed on the service bulletin. I wanted to do this, but I also did not want to screw it up...so I paid a mechanic to watch me do the work! That was 3 months ago....and the noise just started. I jacked up the car, turned it full lock and spun the wheel...no noise. I looked at the magnets...no evidence of a rub. It really sounds like a metallic noise.
I mean rotors as in I am going to replace them. The dealer is aware now and they are on order. This makes sense. Its not the wheel magnets rubbing on the brake duct, which would sound like metal on plastic, its not the fuel line since it happens on 3 corners of the car, it’s not the wheel torque...that was checked and a wheel bearing can be diagnosed by shaking the wheel. I received a PM saying that replacing the rotors fixed the issue.
