open car trailer size
possible spec sheet on the fl website - I could not find it from my phone.
if I guessed - no
I could be wrong though... it would be close
I know a Canadian that ordered an aluma brand alum 14 foot deck trailer so he could put it in his garage... but the *** of his car hangs off the back of the trailer which is a no go for me
Yeah I think it's unrealistic to fit a trailer in a standard sized garage, but I am building a house and am working on the plans. We could extend the garage to 25' if we wanted - if that made keeping a trailer at the house possible, it might be worth it.
now is the time if you are building and have the room
might I also suggest a drive thru garage (doors on both sides) if that will work - never have to back it into the garage... just pull thru and unhook... and never crunch your trailer into a wall etc.
more garage is never a bad thing and if it was not for my wife I would live in a garage with a mezzanine apartment or an RV with an enclosed trailer :-)
I am envious - if it fits your property build it bigger than you think you will ever need.
I had a 3110; I believe it was right at 21' from the tip of the coupler to the end of the 17' 6" bed.
It just fit my garage so I could put the overhead door down. Your car will fit the trailer no problem, even with a tire rack with room to spare at the rear of the trailer.
I like the apparent weight avantage of the various Trailex offerings, but the Featherlite was great, towed straight as an arrow, and was still easy to move around when unhitched.
For resale, the Trailex would probably be quicker, but it's hard to find used 3110s at a good price as well.
J
J
Thanks guys. Unfortunately the pass-through garage is not possible. Sounds like it would fit if we were to make a 25' garage though. The issue is it's two 2-car garages facing each other, so maneuvering a trailer may be impossible anyway. It's probably more realistic to get off-site storage for a trailer.
One thing I added that you cannot see are some deck mounted risers with parking stops for the front wheels. So you simply drive on to the trailer, front wheels go up little riser ramps and into parking stops. This does two things -- easy to accurately place fore and aft on trailer without a second set of eyes telling me to inch forward more more more STOP as I hit the deck mouted box AND it rasies the front end about 2 inches which allows the drivers door to swing all the way open over the trailer tires with the fender removed which makes getting in and out a whole lot easier.
those supports are add ons and available from any trailer supply store... PO put them on... It is never loaded without being hitched... in the shop pic, it is hooked up to a fork mounted hitch ball on the forklift. I would not trust loading without the hitch hook up and just the supports.
... parking stops for the front wheels. So you simply drive on to the trailer, ...and into parking stops.
Thanks for the info.
here is a pic (with my former car) with the race ramps on the ground in front of the trailer
PS: the cayman wheels were being hauled for someone else
I have the same featherlight and love it.
It has a fiberglass valance on the front. I had an aluminum box build and put on the tongue. The trailer length is 17.6". My rs.2 fits great on it. I drive it right on. I tow the trailer behind a gmc dually truck and it pulls amazing on the freeways here in CA.
I dont understand the love affair with trailex, or whatever you call it but it seems like there is alot of happy campers out there.
The featherlight appears to sit lower and the car is easy to load with the right ramps. You can make a custom ramp from foam, so you dont have to mess with 2 x 6 wood. Go to Raceramps.com. They will make anything you need. This along with a set of mac custom tie downs thru the wheel and you can load in about 10 minutes.
No worries
No worries
