GT3 Control Arms
Haven't been on the track yet with this setup; just changed from stock suspension last month and have to wait for the gloomy weather to pass before I can get back on the track. My track wheels are a set of OEM 19" lobster forks, and I've been running R888s (which I think I'm done with once the current set heat cycles out, which will probably occur 5 minutes into my first session....) but have a set of MPSC which have 3 days on them from a road trip to Laguna Seca and will get mounted once the R888s are done....
This last weekend I put on a set of MPSC in stock 19" sizes. They don't seem to have the same grip that the R888 has in it's prime. Anything over 36psi hot and they let go real easy. I found 32/34 to be good.
Wear was good at -2.5 camber front and -2 rear.
I'm going to try out the Pirelli Trofeo next probably.
