Cayman R
tongue in cheek of course, CF will improve and may well be the next thing..... until then, enjoy the blue beast.
Problem with all of these Cayman "fixes" is that none of them address the 987's fundamental weakness, which is not power, but rear suspension. Fixing it would not be a plug and play conversion, getting it to Weissach levels of refinement even less likely. And that's a big advantage that remains firmly in the 911's court.
Naming aside, I too am all for more driver-focused Porsches. Funny how we're pining for those, eh?
pete
pete
At least that my hope. If I wanted a 400+hp 3,800+lb 8 cylinder car, well there are already plenty of those on the market.
As a former Cayman S owner, I hope this Cayman R follows the trajectory of the Boxster Spyder and takes is two (or three!) steps farther. Less weight, less electronics in the suspension, less weight, and less weight.
So that begs the question, whats in the 991? RUF have somewhat intriguingly demonstrated that you can build a l/w V8 for the 997 platform ... what will
Porsche do, extend the 9A1 engine or drop something else instead into the back of the 911?
Some have indicated that the 9A1 engine design is designed to be extended ... hence the flat-8 extrapolation ...
unless they have a l/w V8 in the wings (maybe the same one in the 918?)
But what do I know? Nada.
But what do I know? Nada.[/QUOTE]
me neither ... I personally dont buy into the flat 8 that others have mentioned
The real question for enthusiasts is: what will they race? How much of their racing technology will also shift to green technologies (918 and GT3R-H), and how will that trickle down to the next generation of GT-level cars. I think it is inevitable.
The HP orgy is about to end, IMHO.
Mike
Mike
pete
A Cayman with extra power cannot challenge a GT3, not remotely close.
One just has to get underneath the Cayman/Boxster and the GT3/GT2 (any generation), to appreciate how far better the GT cars are. By the way, this handicap or lack of real performance parts is not unique to the Cayman/Boxster, it is shared by all the Carrera versions, and just recently the Turbo joined them. The GT3/GT2 are too far apart from the rest of the lineup.
I ended with a Cayman S because I could not enjoy the lack of power on a SpecBoxster I had, and the cost to upgrade the SpecBoxster to a 3.4 was higher than buying a newer car (1999 2.5 Boxster vs. 2007 Cayman S), add safety equipment and have it as track ready as the Spec Boxster.
Unfortunately, I realized that adding safety equipment to the Cayman was not going to fit my needs, the car is just not designed to be tracked. So, I planned to upgrade the car, but the cost of the upgrade ( over $150,000) was just too much for a Cayman. Curiously enough, a Cayman S + $150k buys a Scuderia these days, a car that has a better engine/transmission/suspension/brakes than all the GT3 parts you could put in a Cayman.
So here is the list of parts that need to be replaced to make a Cayman as good as a GT3.
- Engine
- Brakes
- Transmission
- Wheel carriers
- axles
- springs/shocks/bushings
- Aero
- starter motor
- power steering pump
- water pump
- alternator
- AC compressor
IMHO, this is pretty much building a GT3 out of a Cayman. All the previously mentioned parts are much stronger in the GT3/GT2.
One of the areas where custom work is required is on the rear Boxster/Cayman wheel carriers, the pickup points are way too high. The little units that come stock cannot be compared with the 2007 GT3 bulky units, and even bigger and bulkier 2010 GT3 units, with the added benefit of lower pickup points for the the rear links. The rear suspension of the Boxster/Cayman is a compromise, there are no upper a-arms or upper control arms, just a single lower control arm, a toe link and a trailing arm, once you put good power and level of grips on these stock pieces, be ready for flexing and unwanted toe/camber dynamic changes.
No idea who can do the work on the rear Boxster/Cayman wheel carriers, but it would require plenty of re-engineering, probably swapping rear GT3 wheel carriers left-to-right and vice versa, plus custom links could work. Not of my interest anyway, as the level of crappy mass production parts in the Cayman/Boxster is just blasphemous for a Porsche.
Years ago I read an european article where a 2007 GT3 was compared against a Cayman with the RUF 410Hp kit+suspension+other goodies. The GT3 beat the Cayman in every performance test, despite of the Cayman being lighter and more powerful.
There is not a single thing a Cayman can do better than a GT3, even if we can detune the GT3 to Cayman power levels (295 HP, 303 HP, 320 HP).
The GT3/GT2 are the perfect examples of "The whole is greater than the sum of the parts".
