Recommended Brake Fluid for RS?
It's a way off I know, but for next Spring's track prep, what should I do brake fluid-wise for the RS? The car will have break in miles by then. Car has PCCB. I don't know what Porsche puts in OE. What is recommended? Motul? Castrol SRF?
Everyone has their favorite brake fluid... Motul RBF 600 is very popular as is Castrol SRF. Some folks find the increased time interval between bleeding on the SRF a cost effective measure while some prefer to bleed the lower cost RBF 600 before each track event. Either approach seems to work just fine.
I've been using Endless RF650 which is factory-fill for the GT3 racecars.
https://rennlist.com/forums/997-gt2-...id-review.html
Still plays with cars.
Motul RBF 660
What's the status on the Castrol synthetic and Motul red?
Last I heard from Porsche, neither was approved -- the Castrol is too corrosive and the Motul causes seal failure.
Endless is something I have tried.
http://www.endless-brake.info/e_layer_product.htm
Strange that their Web site uses the image of a brake coming to its end.
I flush with ATE alternating blue/yellow once a year, I never have to bleed and have zero trouble with the pedal.
Has anyone ever placed a non-reversing temperature label on the calipers to measure the maximum temperature? Mcmaster Carr has 9/16" diameter labels that has 5 temperature points. I am thinking of getting 340f-380f (9246T23) and 390f-435f (9246T25). I am thinking this way you can determine your caliper temperatures and give you a better idea about the brake fluid needed. Any thoughts?
My tech has been using SRF in track Porsches for years and says he never saw any problems with it. He says that is an urban myth. I have used SRF in my heavier turbo for 3 years now. Even though I track it, I never had to bleed it or give it a second thought. Never had any brake problems either.
Also, given that ATE works, I see no merit in the expensive 600F stuff.
As for temp tags, the only thing would be to get advice from a brake oem to determine where to put the tags to get indicative temps.
The only "trick" I can suggest for better brake performance from the piston/fluis side, is a Titanium insulation plate slotted in behind the pad backing plate once the pad is down 10-20% wear (it often won't fit in behind a fresh pad) but this won't help the rotor heat soak that would jeopardize the CCBs.
I ran ATE superblue in my TT which had GT3 brakes. Tracked it pretty hard and no issues. Maybe I should not rock the boat and just stick with it. I just seem to remember guys knocking it, claiming it was no better than OEM/street fluid.
GT3 player par excellence
I've tried most of them, finally went to Castrol SRF despite the high cost and I am sticking with it. Costs more but I am not getting constant soft peddle and don't need to bleed every event like I did with other fluids.
Not sure I can quite say you'll save the cost with less bleeding if DIY (like I do), but you sure will if you're paying someone to bleed for you.
