Recommended Brake Fluid for RS?
Depends on how you want to use it. As I understand it the dry/wet boiling points are:
Endless 323 C / 218 C
SRF 310 C / 270 C
So, Endless is better (higher boiling point) fresh out of the bottle - if you bleed before every event, save money and use Endless. But if you don't want to bleed before every event the much higher "wet" boiling point of SRF is a real advantage - since after some time in your master cylinder the fluids absorb moisture and become "wet".
SRF 310 C / 270 C
SRF 310 C / 270 C
SRF 310 C / 270 C
After being disappointed in ATE gold and blue, and Motul 600 & 660 when they boiled at every event, I switched to SRF without trying any more fluids along the way - maybe if I had seen your write up a year ago I would have tried Endless.
Hey, if you are happy with Endless that's great. Similarly, I have been happy with SRF and plan to stick with it.
So where is a good place to get the Endless fluid.
I've been using Motul RBF660 an it works well but I can boil the fluid especially in the summer. I bleed for every event too. Flush after around 5 events.
Here's a place. Note that the bottles are small, 0.5L:
http://www.worksevo.com/store/produc...=google-simple
I replace SRF when I replace pads. Thats 4 track events or 4 months. I never bleed in between.
On days 6-7-8 the pedal gets softer, but I think that is just the worn pads and extra heat? The car always stops.
