Help Please- Spring Rates OE F/R for 2010 RS and Spyder?
If anyone would be able to post OE F/R spring rates specifically for 2010 GT3RS and 2011 Boxster Spyder I would appreciate it immensely and promise you a very interesting future thread.
Received 1,853 Likes
I don't have numbers but I do recall Preuninger comment that they went softer on suspension in new GT3/RS (not sure whether springs or shocks) and alluding to view that perhaps they went too soft.
FWIW, speaking to van der Weerd about the Spyder, I believe he said they went up 10 percent on front spring rate and up EDIT: 30 percent in the rear (from stock Boxster S) — which is why the Spyder is so much keener to turn in than a Cayman S.
Will go back to the recording to see if I got numbers out of him, but they usually don't like to share them.
pete
pete
I *thought* the spring rates were written on the springs themselves ... although its a pain to jack the car to find them ...
did they not also go to a progressive on the .2 over the .1 ... or I am thinking of the 996 vs 997?
No luck so far ![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
The "Technik" book for my (beloved but departed) 2009 C4S listed ALL the specifics. Spring rates and design for each model iteration. However my super-excellent-Master Porsche Tech who is a true diamond in a sea of coal tells me no such book was published by Porsche for the new RS and Spyder. He did get me a price for the Spyder prings which was actually pretty cheap, but contrasted with the RS rear springs which are freaking ridiculou$. And all springs are only in Germany.
I emailed the user over at TeamSpeed who had the KW variant 3 struts installed on his Spyder to see if I could "rent" his old struts for non-destructive testing but no reply![crying](https://rennlist.com/forums/graemlins/bigcry.gif)
As well I found some suspension tuning tweaks alluded to by P-car engineers on both cars but really need the darn specifics. My P-Tech did tell me the part numbers for 2010+ GT3 and GT3RS springs are the same. But I need rates to establish a baseline and proceed in considered and reasoned fashion.
And if I have the shocks/struts I can dyno them to see where baseline compression and rebound curves are.
If anyone has removed springs / struts from a 2010+ GT3 (preferable RS) and would loan them to me I would pay for shipping and a rental fee
As always I will post for the greater good what I discover and results of a super-awesome tweaking project I have planned
Admin
You don't deserve the title of Chief Executive Researcher but gladly I ll hire you as my assistant. ![Big Grin](https://rennlist.com/forums/images/smilies/biggrin.gif)
FRONT:
997.1 GT3
PART NUMBER: 996 343 531 95
SPRING RATE: 40N/mm
997.2 GT3
PART NUMBER: 997 343 531 94
SPRING RATE: 49N/mm
REAR:
997.1 GT3
PART NUMBER: 997 333 531 93
SPRING RATE: 105N/mm
997.2 GT3
PART NUMBER: 997 333 531 95
SPRING RATE: 115N/mm
John
FRONT:
997.1 GT3
SPRING RATE: 40N/mm
997.2 GT3
SPRING RATE: 49N/mm
REAR:
997.1 GT3
997.2 GT3
John
FRONT:
997.1 GT3
SPRING RATE: 40N/mm
997.2 GT3
SPRING RATE: 49N/mm
REAR:
997.1 GT3
997.2 GT3
John
FRONT:
997.1 GT3
SPRING RATE: 40N/mm
997.2 GT3
SPRING RATE: 49N/mm
REAR:
997.1 GT3
997.2 GT3
John
