Catastrophic Coolant Hose Coupling Failure Registry
#76
2011 ***
GT3
2200 miles ***
Yesterday
Spun but recovered.
Near front right wheel. Link did not fail, but plastic pipe developed a hole/weakening.
Car at dealer.
REALLY ANGRY RIGHT NOW.
GT3
2200 miles ***
Yesterday
Spun but recovered.
Car at dealer.
#78
This is a new type of failure. A couple of pics would be handy to identify exactly where the part failed -- it could be entirely unrelated if something got to point of failure and caused the line to split. Either way, it's disconcerting to say the least.
#79
Year: 2007
Model: GT3
Mileage: about 8800
Incident Details: Sebring - cool down lap solo group (THANK GOD!)
Pulled over by safety crew as I was coming off the track. They said "The corner workers said one of the white GT3's was dripping fluid from the rear. We need to check all of them"...at Sebring, this could be quite a few cars on any given weekend. Shoot...it's my car! Temp and oil gauges still read normal. By the time I got to my paddock, it totally let go. Fluid was dumping from the front of the engine on the driver's side. Car was flat bedded to dealer today. The dealer says they have never seen this before and never heard of this before. I shutter when I think of what could have happened. Me, a brand new GT3RS and 4 Z06's running in a pack...Yikes.
What Broke: The brass fitting separated from the aluminum casting. It is the hose fitting behind the alternator on the driver's side
Fix: It is at the dealer. They just said they will repair it under my CPO warranty.
Given this registry of repeat failures, it is Water wetter and water for me.
Model: GT3
Mileage: about 8800
#81
I just switched over to water and Water Wetter and the weather immediately decided to dip well below freezing every night! I am closing up my garage and running a little space heater all night to make sure the temp stays above freezing. I sure hope it warms up enough that we're not seeing these temps in two weeks, when my first track event of the year is scheduled. I am forcefully reminded of very cold nights at DEs, especially in the fall at Pocono and the Glen, and wonder whether I will need to go back to antifreeze to cure high anxiety about overnight damage.
#84
I don't want to hijack the purpose of this thread, but I have a question about water wetter. What is the mixing ratio (% water to % water wetter)? I also understand this system is pressurized?
#86
#88
Year: 2007
Model: GT3
Mileage: about 8800
Model: GT3
Mileage: about 8800
If you have any non-Loch-Ness-Monster (fuzzy, out-of-focus) photos, it would be interesting to know which hose fitting failed on your car.
As for the dealer -- if they're prepared to say they've not heard of it, then they're certainly not listening to their own internal technical bulletins and perhaps they're lying to you. In either case, you need to take control and not leave it to the dealer.
#89
Has anyone opened a complaint or complaints with the NHTSA? Although this is a smaller problem, I know that the complaints filed on the BMW HPFP issue helped finally get a recall.
#90
Thanks for all the info. I don't have a better picture. My failure is the fitting behind the alternator (not my photo talents CGT, but the shop). I will have Orbit Racing take care of the Water Wetter. They do all of my non-warranty work already...and many thanks to Orbit Racing for transporting my car from Sebring to WPB and getting everything worked out with Porsche to have this fixed under warranty.
