New Centerlock Specs/Torque For Track Use. **Read This**
#121
![Exclamation](https://rennlist.com/forums/images/icons/icon4.gif)
Add your name to the list if interested:
https://rennlist.com/forums/997-gt2-...to-5-bolt.html
#123
Just another data point here but I greased the nuts per the TSB, took it to the track, and checked torque each day to higher spec. Certainly no looser. Then when I needed to take off the wheels, I found the effort to be considerably higher than I had ever previously experienced it. In fact, I was beginning to wonder if I COULD do it (I weigh 180 lbs, had my FULL weight on the bar and it only barely budged with great difficulty but in the end, I was able to do it. I am going to try at least re-greasing the conical surface each time the nut comes off to see how that goes.
#124
I would recommend pulling up on the breaker bar. It's hard to put the required force needed to break the wheels when pushing down.
But pulling up is MUCH easier. As you push upwards with your legs. I also weigh 180 lbs and had a bit of difficulty when pushing down.....easier pulling up and using legs.
Thinkl deadlift.....vs bench press
#125
All this and the damned things are HEAVY, to boot. Careful what you wish for. P certainly has a great sense of humor, don't they?
Change back to lugs, have more fun, weigh less, drive more.
#127
Always use your weight to advantage, and let the lever arm help you instead.
Please be safe...
SNB
#128
1. is there a shelf life for this stuff? i.e. can I order a few tubes to store so I always have some on-hand.
2. How long should a tube last - 1 tube = 1 4 wheel swap?
thanks,
#129
Official Wednesday AM Red Bull F1 test driver
Wouldn't a good marine grease work fine for this? Do we really need the Porsche stuff? It is currently backordered at the couple places I've tried to get it. The grease is mainly there so things don't get surface rust, right??
#130
I don't have CL's yet but that is exactly what I was thinking. Being a boater I have marine grease on hand all the time.
#131
#132
#133
I found the paste online at http://www.gaudinjaguarparts.com/ for $20.69. Questions:
thanks,
thanks,
#134
I *think* that the grease might effect the friction coefficient, so I would not replace the Porsche lubricant with any arbitrary grease.
#135
This grease is participating in the friction calculations for the torque and load bearing of the lock nut. It has to remain consistent across a wide range of operating temperatures and conditions. The Porsche branded tube of grease is quite likely an generic grease suited to high temp and high pressure applications, but it could have other properties (its adherence to the particular working surfaces, it's reluctance to attract contaminants, etc.) "Marine" greases are lithium-molybdenum with the general purpose of being waterproof and not promoting electrolysis. These are breeds of the same species, but not interchangeable; at least, not without specifications of the Porsche goop.
