How many trackdays with your tyres?
FWIW - is your car aligned for track? I assume you mean the Corsa System tire which is one of the OEM tires for the Gt3 RS. Great tire but not as good as a real R-Compound.
Aside to John, I tried the R 888 and hated them. I mean hate! Horrible squirm and no more grip than the Corsa system tires. Maybe a bad set but I was seriously disappointed. Now using Hoosiers (R80/R100).
What is your wear like on the R80/100? [vs R6s]
-td
I get about 32 to 35 sessions out of a set of MPSCs. Those are generally 25 minute sessions on average. Then they are toast. So, assuming 4 sessions a day that is about 8 track days.
I generally swap them side to side between day 1 and day 2 of any given event. That helps. As does not having them over or under inflated. Third explanation is that perhaps I am moving a lot slower than you are.
http://www.flickr.com/photos/5138615...7624623551065/
here you go.
First 5 are from the left-front one, 6 is left rear, 7 & 8 are right front.
here you go.
I use R888s, and I have 1420 track mi. and 3930 street mi. on the fronts; rears have 985 track mi. and 2730 street mi. on them. And they have still quite a bit of thread left, their performance is not what they were (~1-1.5 sec slower compared to new), but they should be good enough for me the rest of the DE season.
I've done 42 hc's on kuhmo v710's on my 6. I did flip them and rotate them to maximize life. Did 18 hc's one side and 24 hc's on other side before they corded and this is driving to/fro track. Best tire I've used for longevity and grip. Mike
