Increase Camber for GT3 RS MK2
Hi Guys,
I am trying to turn the top hat on the front strut of my RS to increase camber. The problem is that the studs need to be removed and reinserted. I don't know how to remove the top hat studs without doing any damage to the stud or top hat. If anyone can help, it would be greatly appreciated.
Regards
RS LOVER
Regards
RS LOVER
To rotate the front struts, just have the car off the wheels, remove the three nuts, lower the entire strut-wheel carrier assembly just a few mm below the tower -- without any disassembly -- then rotate to the only other position where the studs line up with the holes/slots in the strut tower and reinsert.
When I tried I ended up removing the whole strut tube/spring assembly to be sure not to damage anything. Then remove the camber plate. The 3 studs have to be pressed out and repressed into the 3 empty holes. When you reinstall it rotates the camber plate 180°. Then you will get -1.5° to -3°+ camber. Ride height, corner balance and alignment required. One day and 12 beer job.
You do not need to do that to increase camber on the MK II......I have -2.5 without rotation???This is according to my mechanic who did the set up.
Thanks for all the comments guys. I managed to remove the top hat and take out the lug bolts and reinsert in the separate holes. Then replaced the top hat and have more camber.
I could not get anywhere near 2.5 degrees negative with the hats set up from the factory.
Regards
RS LOVER
Regards
RS LOVER
