997 GT2/GT3 Forum 2005-2012
BBS wheels and PAGID pads
Old 07-04-2010, 06:24 PM
  #31
ZSA Motorsport
Former Vendor
ZSA Motorsport's Avatar
Originally Posted by cfjan
In order to get the car on the lift, the shop I go to would use a jack on the engine case to lift the car up a little bit to get the car high enough for the lift arms to go under.. I guess it is a not so uncommon practice..
yes, but dont presume because a shop does it that its right either.
soemtimes they do stuff because its easy.
after all its your car, not theirs.
Old 07-04-2010, 06:44 PM
  #32
tcsracing1
tcsracing1's Avatar
i cant believe these wheels and pads are not gone yet!
is anybody here using their .2RS on the track yet??
Old 07-04-2010, 07:31 PM
  #33
cfjan
cfjan's Avatar
That is very true.. I agree w/ you 100% there..
But from what I can see.. they use the point where the cases join together. It looks to be a pretty strong point.
Old 07-04-2010, 08:05 PM
  #34
mooty
GT3 player par excellence
mooty's Avatar
Received 5,691 Likes on 2,339 Posts
not many RS around.
looks like i will have to accumulate more stuff ;-)
i'll save them for you, tom, when i sell you my 2010RS.
Old 07-04-2010, 08:35 PM
  #35
tcsracing1
tcsracing1's Avatar
Originally Posted by mooty
not many RS around.
oh man that actually sounds good!
im gona be broke!
Old 07-04-2010, 11:46 PM
  #36
P.J.S.
P.J.S.'s Avatar
just remember who has first dibs on that trailer ;-)
Old 07-05-2010, 12:12 AM
  #37
mooty
mooty's Avatar
you got it.
996flt6 wants a stacker. convince him to cough up 25k, then i will put in 25, so we get stacker you have mine
Old 07-05-2010, 03:40 AM
  #38
wurlie
wurlie's Avatar
the off set is too aggresive for non RS, so it's pushed out.
however, BBS at GA headquarter did tell me that if you run it with track alignemnt on non RS, you will be ok. i take that to be no less than 2.5 deg
here is the offset
9x18 ET43mm
12x18 ET48mm
my "guess" is that they will fit. but i can't guarantee it and i dont want ppl to get upset at me if the rubber touched fender lip.
just like 996gt3, if you run 12, your fender lip is rubbed. you ca'nt see it usually. but take wheel off, get your head inside the fender then look OUT toward the lip, you will see rub mark. most ppl dont detail that part of their cars. so they tell you they dont rub.. but 12" rear will rub 996 unless you roll fenders.
Thanks a lot, that's what I was thinking.
Very considerate!
Best regards, w
Quick Reply: BBS wheels and PAGID pads
